03.08.2021, 17:11 | #1 |
axinthefield: Application Version 10.0.21 is Available for Public Preview
Источник: https://community.dynamics.com/ax/b/...public-preview
============== Application version 10.0.21 is now available for public preview. If you are interested in learning more about getting access to preview builds through the Public Early Access Program (PEAP) please check out a blog I wrote here. There is also a known issue with the build that I've documented at the end of the blog. For a listing of all KBs included in this release, you can find the list here. Below are 10.0.21 features marked as preview under the new tab in feature management: Feature name Module Inventory closing progress details This feature enables a detailed view of inventory closing progress. Cost management (Preview) Priority driven MRP support for Planning Optimization This Planning Optimization preview feature enables master planning driven by planning priority with reorder point. Highlighted changes: - ‘Planning priority’ field on Sales order line, Purchase order line, Demand forecast and Planned orders. - A new Coverage code option - Item coverage field for Reorder point. - Master planning setup forms to control the ‘Planning priority’ setup. - Planning Optimization calculation logic to set and respect ‘Planning priority' Master planning Allow to set up ER destinations per print management item This feature allows you to configure destinations of outbound documents that are generated by an Electronic reporting (ER) format when this format is selected in Print management (PM). Selecting the same ER format in different PM items, you can configure different destinations. Organization administration Prevent overconsumption of general budget reservations when multiple purchase requisitions are in workflow This feature improves error checking when users submit and approve purchase requisitions that exceed the remaining balance of a general budget reservation line. This helps prevent overconsumption of general budget reservations when multiple purchase requisitions are in workflow. Procurement and sourcing (Private Preview) Enable project purchase orders on Project Operations for resource based/non-stocked scenarios. This feature will allow user to create project related purchase orders in Legal entities with Project Operations on Dynamics 365 Customer Engagement integration enabled. Project purchase orders can be used to record non-stocked materials procurement against the project by Procurement department persona. Project Purchase Order will not sync to Dataverse, however you can use virtual entity to surface Project purchase order lines in Dataverse for Project Manager information. Project related vendor invoice cost is integrated to Project Actuals entity in Dataverse. Project cost is recorded in Project subledger using Project Operations Integration journal. Project management and accounting Enable a mechanism to represent dimensions as swatch Product dimension could be represented as a swatch. In this feature we want to provide a mechanism to represent dimensions as swatch and enable it on e-commerce. Retail and commerce Scan GS1 barcodes Enables the Warehouse Management mobile app to scan GS1 barcodes. Warehouse management Use faster API for containers closing/reopening on packing station When this feature enabled inventory transactions related to containers are created using new lite weight process to improve performance of closing or reopening containers during manual packing station processing. Warehouse management Features marked new in 10.0.21 but are no longer marked as preview: Feature name Module (Mexico) Adds new field Settled amount in the CFDI (electronic invoices) payment and this field value is output in attribute Monto. Accounts receivable NF-e custom certificate validation Accounts receivable Include narrative fields when copying a budget plan Budgeting (Belgium) CODA bank statement processing performance improvement Cash and bank management Turn off set based updates for customer settlement cash discount date Cash and bank management Validate Finance insights configuration (On by default) Cash and bank management This feature enables multi-threading when creating collection letters in batch Credit and collections (Brazil) SPED Reinf updates in events 5011 and 2055 Fiscal books Prevent multiple depreciation in same period Fixed assets (Russia) Include opening and closing period types when calculating balances in financial reports General ledger Dimension attributes values collection optimization in ‘MasterFiles’ report section of SAF-T for Norway (On by default) General ledger Sealed bidding for RFQs Procurement and sourcing Show full serial, batch, and license plate numbers in the production floor execution interface Production control Allows future transactions to be allocated to a budget in the current period. Project management and accounting Create project estimates using multiple batch tasks Project management and accounting Make Project Hour journals read-only if current approval status doesn't allow editing. Project management and accounting Post Project Operations integration journal using multiple batch tasks Project management and accounting (Brazil) NFC-e synchronous processing Retail and commerce (Russia) Customer information management in Retail POS Retail and commerce Enable generation of a stronger channel reference ID Retail and commerce Enable Russian simplified customer address format Retail and commerce Prevent unintentional price calculation for commerce orders. (On by default) Retail and commerce Sales quotation referenced data export policy Sales and marketing (Eastern Europe) Allow to settle Customer/Vendor transactions if there are several voucher transactions with type Customer balance/ Vendor balance Shared AP and AR Improved legal entity support for saved views System administration Skip writing batch constraints history System administration (India) Enable posted withholding transaction form for TDS/TCS Tax Performance improvements for VAT register transactions form Tax VAT statement format reports. Tax Withholding tax payment against vendor account Tax Decouple putaway work from ASNs Warehouse management Post on-hand adjustments using configurable reason codes connected to offset accounts Warehouse management Slot mixed units Warehouse management Warehouse app step instructions Warehouse management Prevents multiple executing Workflow message processing batch jobs. (On by default) Workflow There is a known IaaS deployment issue in the preview release and a fix is already in the works. Here is the message that was posted in Yammer: ----- Known deployment issue for release 10.0.21 Application: 10.0.960.20 Platform: 7.0.6129.15 When deploying release 10.0.21 on IaaS, you may receive the following deployment warning: Warning code 95017 Warning message Script [SetupDiagnostics] failed execution against VM The deployment will work despite the warning, however, the following known issues may occur in Lifecycle Services (LCS):
----- Thanks for reading! Please connect with me on LinkedIn for future AX in the Field blog posts and discussion. We also have several workshops, chalk talks, and assessments available to help you get the most out of your D365 Finance and Supply Chain Management investment. Click here for a listing of our service offerings and reach out to your Customer Success Account Manager (CSAM) for more information on how to get started. Источник: https://community.dynamics.com/ax/b/...public-preview
Опции темы | Поиск в этой теме |
Опции просмотра | |
