Старый 10.11.2006, 01:36   #1
casperkamal: Parsing Source Code
Источник: http://casperkamal.spaces.live.com/B...CD63!141.entry
     Sometimes its required that we parse the source code written in the classes, Axapata has a class that will help us in doing this. SysScanner Class is the one that will do the Job, it has so many options that will help us in parsing the code easily. Here is a small piece of code on that.
static void JobSysScannerClass(Args _args)
    #AOT
    TreeNode        treeNode   = TreeNode::findNode(#Classespath + '\Class1\Check');
    SysScannerClass sc         = new SysScannerClass(treeNode);
    int             lineCnt = 1;
    while (lineCnt < sc.lines())
        print sc.sourceLine(lineCnt);
    pause;
it also has options to find if the code has the standard symbols like ttscommit, ttsbegin, print,
for this you have to use the Macro #tokentypes which has the integer values for all the standard key words
..................My first showpiece
Kashperuk Ivan: Tool for protecting your Dynamics AX source code Blog bot DAX Blogs 0 12.12.2008 04:07
casperkamal: Using record templates in code for Dynamics Ax 4.0. Blog bot DAX Blogs 0 10.05.2008 19:14
casperkamal: Sending alerts through code without error in Ax Blog bot DAX Blogs 0 24.03.2008 21:05
casperkamal: A small addition to creation of Table throug x++ code in Dynamics Ax Blog bot DAX Blogs 0 03.04.2007 23:11
casperkamal: Code Access security Blog bot DAX Blogs 0 10.11.2006 01:36
Часовой пояс GMT +3, время: 12:52.
