Старый 23.08.2007, 05:32   #1
Solutions Monkey: WSS Setup for EP - Basic or Advanced Mode ?
Источник: http://blogs.msdn.com/solutions/arch...nced-mode.aspx
Microsoft Dynamics AX Enterprise Portal supports both Advanced mode and Basic mode installation of WSS. “Advanced” is the recommended approach for production systems.The difference between Basic and Advanced mode of SharePoint is well documented by SharePoint documentation http://office.microsoft.com/en-us/winsharepointadmin/HA011607841033.aspx.
The limitations in Basic mode ( which uses WMSDE) includes lack of sql mgmt tools , full text search , db size etc. WMSDE could be used for light usage scenarios or as dev env and can later be migrated to a regular sql server installation.
Advantages of Server Farm Configuration
• Performance and capacity could be increased by adding additional servers running Windows SharePoint Services and SQL Server.
• Load balancing could be achieved by using hardware or software (NLB) service.
Solutions Monkey: EP SSL ( https) Setup Blog bot DAX Blogs 0 23.10.2008 12:05
Solutions Monkey: EP/Role Centers in WSS vs MOSS Blog bot DAX Blogs 0 29.07.2008 04:09
Solutions Monkey: EP Site Templates not appearing under "Custom Tab" in WSS 3.0/MOSS 2007 Blog bot DAX Blogs 0 14.06.2007 03:52
Solutions Monkey: Enterprise Portal on WSS 3.0 – Ax32.exe.config Blog bot DAX Blogs 0 09.01.2007 22:51
Solutions Monkey: Quick Steps to setup Enterprise Portal in a cluster Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 14:08.
