Старый 17.10.2007, 22:40   #1
daxmy: Tips: Enable company/user template when created new form with new table
Источник: http://daxmy.blogspot.com/2007/10/ti...late-when.html
It is pretty simple. Go and check your new table, look at TableGroup property, and set the value to Group/Main.
There is some info in Dev Guide 4.0 (grabbed from internet):
Table groups constitute a way to categorize tables according to the types of data they hold. Determining group membership, though, is not an exact science but more of a conceptual definition. But when determining group membership for your own tables, follow the standards in the Microsoft Axapta application.
Parameter
The table holds data primarily used as parameters or setup information for one of the Main tables. The table typically holds only one record.
CustParameters, VendParameters
Group
The table holds data primarily used to categorize one of the Main tables. There is a one-to-many relationship between Group and Main.
CustGroup, VendGroup
Main
The table is one of the principal tables in the application and holds data for a central business object. The table typically holds static, base information.
There is a one-to-many relationship between Main and Transaction.
CustTable, VendTable
Transaction
The table holds transaction data. Typically the table is not used for data entry directly.
CustTrans, VendTrans
WorksheetHeader
The table typically categorizes information in the WorkSheetLine tables.
There is a one-to-many relationship between WorkSheetHeader and WorkSheetLine.
SalesTable
WorksheetLine
The table holds information to be validated and made into transactions. Compared to the information in Transaction tables, the information in WorkSheetLine tables is temporary and may be deleted without affecting system stability.
SalesLine
Miscellaneous
The table does not fit in any of the other categories.
Khue Trinh: CODE TO CHANGE FORM BACKGROUND COLOUR FOR EACH COMPANY Blog bot DAX Blogs 1 28.01.2008 10:39
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
jerry-dynamics: How can you make sure that the end user can not delete a record in one table if there are related records in another table? Blog bot DAX Blogs 0 16.06.2007 11:20
PatrickChua: Temporary table Blog bot DAX Blogs 0 28.10.2006 18:14
Часовой пояс GMT +3, время: 15:01.
