Старый 30.10.2007, 05:03   #1
Solutions Monkey: Installing SQL Reporting Services and MOSS 2007 on the Same port ( default : 80)
Источник: http://blogs.msdn.com/solutions/arch...efault-80.aspx
If you have both MOSS 2007 ( Microsoft Office SharePoint Server) and Reporting Services ( not in SharePoint integrated mode) installed on the same IIS virtual server, then you have to make the below updates in web.config for them to work
1) In the Root web.config to comment out the below. Otherwise the reportserver will give sessionState partitionResolver Issue
2) In both Reportserver and ReportManager vdir web.config, the following should be added under appSettings. Otherwise you will get ReportViewer error messages
This is because , by default MOSS uses /reports url for it’s report center and it’s the same virtual dir url for native SQL Reporting Services report manager as well.
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: EP/Role Centers in WSS vs MOSS Blog bot DAX Blogs 0 29.07.2008 04:09
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Solutions Monkey: EP Site Templates not appearing under "Custom Tab" in WSS 3.0/MOSS 2007 Blog bot DAX Blogs 0 14.06.2007 03:52
Часовой пояс GMT +3, время: 12:46.
