Старый 15.12.2007, 20:35   #1
C# and AX Development: Using the COM Business Connector in C#, the easy way (AX/Axapta)
Источник: http://olondono.blogspot.com/2007/12...in-c-easy.html
The easy way to perform tasks with the COM Business Connector in Axapta/AX is creating a class in the AOT and calling it from C#. Here I will show the hard way and the easy way, the axample queries the CustTable for read his name.
1. THE HARD WAY
// Logon
Axapta2Class ax = new Axapta2Class();
ax.Logon("username", "", "", "myConfig");
// Make the query
IAxaptaObject query;
IAxaptaObject queryrun;
IAxaptaObject querybuilddatasource;
IAxaptaObject querybuildrange;
query = ax.CreateObject("Query", null, null, null, null, null, null);
querybuilddatasource = (IAxaptaObject) query.Call("AddDataSource", 77, null, null, null, null, null); // CustTable Id = 77
querybuildrange = (IAxaptaObject)querybuilddatasource.Call("AddRange", 1, null, null, null, null, null); // AccountNum Id = 1
querybuildrange.Call("value", "3507", null, null, null, null, null); // 3507 is my custom query value
queryrun = ax.CreateObject("QueryRun", query, null, null, null, null, null);
queryrun.Call("prompt", null, null, null, null, null, null);
// Process result
if ((bool)queryrun.Call("next", null, null, null, null, null, null))
IAxaptaRecord custtable = (IAxaptaRecord)queryrun.Call("getNo", 1, null, null, null, null, null);
// Show customer's name
MessageBox.Show((string)custtable.get_field("Name"));
if (Marshal.IsComObject(custtable))
Marshal.ReleaseComObject(custtable);
custtable = null;
// CleanUp
if (Marshal.IsComObject(query))
Marshal.ReleaseComObject(query);
query = null;
if (Marshal.IsComObject(queryrun))
Marshal.ReleaseComObject(queryrun);
queryrun = null;
if (Marshal.IsComObject(querybuilddatasource))
Marshal.ReleaseComObject(querybuilddatasource);
querybuilddatasource = null;
if (Marshal.IsComObject(querybuildrange))
Marshal.ReleaseComObject(querybuildrange);
querybuildrange = null;
// Logoff
ax.Logoff();
if (Marshal.IsComObject(ax))
Marshal.ReleaseComObject(ax);
ax = null;
// Release AxCOM.dll for close this session definitely
ApiWin32.CoFreeUnusedLibraries();
2. THE EASY WAY
// Logon
ax.Logon("olondono", "", "", "Axapta9");
// Make a call to our class and get the Customer
IAxaptaObject classTest = ax.CreateObject("COMTest", null, null, null, null, null, null);
IAxaptaRecord custtable = (IAxaptaRecord)classTest.Call("getCust", "3507", null, null, null, null, null);
// CleanUp
custtable = null;
if (Marshal.IsComObject(classTest))
Marshal.ReleaseComObject(classTest);
classTest = null;
// Logoff
ax.Logoff();
ax = null;
And the Axapta class looks like:
class COMTest
public CustTable getCust(str _custAccount)
Query q;
QueryRun qr;
QueryBuildDataSource qbds;
QueryBuildRange qrange;
TableId _tableId;
CustTable _custtable;
_tableId = tablename2id("CustTable");
q = new Query();
qbds = q.addDataSource(_tableId);
qrange = qbds.addRange(fieldname2id(_tableId, "AccountNum"));
qrange.value(_custAccount);
qr = new QueryRun(q);
qr.interactive(false);
qr.prompt();
if (qr.next())
_custtable = qr.getNo(1);
return _custtable;
Why I prefer the easy way? because I can change the Axapta class without affect the C# application anyway. And coding AX Applications with AX busines rules is more naturally in the AOT than in C#, normally, we use the C# application as an interface, so, code must be kiss (Keep It Simple and Stupid).
Часовой пояс GMT +3, время: 21:04.
