Старый 20.03.2008, 14:05   #1
axStart: Always add str tostring() method on your class for debug purpose.
Источник: http://axstart.spaces.live.com/Blog/...C0A0!285.entry
Did you ever wonder how the debug is able to add watches on object?
Sometimes you get additional information like on the class QueryBuildRange. But on your own class you get nothing. The reason is that you did not implement the tostring method on your class. Lets do this example:
str tostring()
    sysdictclass sdt = new sysdictclass(classnum(class1));//hard coded because AX has no WhoAmI method
    sysdictclass extendsSdt = new sysdictclass(sdt.extend());
    str result;
    result = strfmt('%1 | ',sdt.toString());
    if(extendsSdt)
        result += strfmt('extends %1 | ',extendsSdt.toString());
    result += strfmt('run on %1',xglobal::clientKind());//also possible to se with the icon in the debugger in AX 4.0
    return result;
Now you are able to se what kind of class is used. This is just an example but from now, you can make everything visible in the debugger.
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 04.04.2009 22:05
Sample Design Patterns: SysDictClass method implementedBy() returns as if class implements itself Blog bot DAX Blogs 0 25.10.2007 05:44
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Kashperuk Ivan: Description of ClassBuild class:Today I want to ... Blog bot DAX Blogs 0 26.01.2007 05:51
Часовой пояс GMT +3, время: 18:03.
