Старый 14.05.2008, 15:40   #1
Wamr is offline
Wamr
1,737 / 868 (32) +++++++
Записей в блоге: 7
Ускорение стандартного импорта
Промаявшись с импортом проводок по клиентам, решил в классе SysDataImport заменить пару временных таблиц на Map
class SysDataImport extends SysDataExpImp implements sysDeleteTables
    // шустрый импорт -->
//    TmpTransactionIdMap     old2NewCreatedTransactionId;
//    TmpTransactionIdMap     old2NewModifiedTransactionId;
    // шустрый импорт <--
void new()
    old2NewCreatedTransactionId = new Map(Types::Integer, Types::Integer);
    old2NewModifiedTransactionId = new Map(Types::Integer, Types::Integer);
private void updateTransactionId(TableId _tableId, CreatedTransactionId _oldCreatedTransId, ModifiedTransactionId _oldModifiedTransId)
    CreatedTransactionId    newTransId = 0;
    if (!hasTransIdSupport)
        return;
    if (hasCreatedTransId[tableIds[_tableId]])
//        select old2NewCreatedTransactionId where old2NewCreatedTransactionId.Id == _oldCreatedTransId;
//        if (old2NewCreatedTransactionId)
//            newTransId = old2NewCreatedTransactionId.RefId;
        if(old2NewCreatedTransactionId.exists(_oldCreatedTransId))
            newTransId = old2NewCreatedTransactionId.lookup(_oldCreatedTransId);
        if (newTransId)
            curCommon.(new DictTable(curCommon.TableId).fieldName2Id(extendedtypestr(CreatedTransactionId))) = newTransId;
        else
            curCommon.(new DictTable(curCommon.TableId).fieldName2Id(extendedtypestr(CreatedTransactionId))) = nextTransId;
//            old2NewCreatedTransactionId.Id    = _oldCreatedTransId;
//            old2NewCreatedTransactionId.RefId = nextTransId;
//            old2NewCreatedTransactionId.insert();
            old2NewCreatedTransactionId.insert(_oldCreatedTransId, nextTransId);
            nextTransId++;
    newTransId = 0;
    if (hasModifiedTransId[tableIds[_tableId]])
//        select old2NewModifiedTransactionId where old2NewModifiedTransactionId.Id == _oldModifiedTransId;
//        if (old2NewModifiedTransactionId)
//            newTransId = old2NewModifiedTransactionId.RefId;
        if(old2NewModifiedTransactionId.exists(_oldModifiedTransId))
            newTransId = old2NewModifiedTransactionId.lookup(_oldModifiedTransId);
        if (newTransId)
            CurCommon.(new DictTable(curCommon.TableId).fieldName2Id(extendedtypestr(ModifiedTransactionId))) = newTransId;
        else
            curCommon.(new DictTable(curCommon.TableId).fieldName2Id(extendedtypestr(ModifiedTransactionId))) = nextTransId;
//            old2NewModifiedTransactionId.Id    = _oldModifiedTransId;
//            old2NewModifiedTransactionId.RefId = nextTransId;
//            old2NewModifiedTransactionId.insert();
            old2NewModifiedTransactionId.insert(_oldModifiedTransId, nextTransId);
            nextTransId++;
private void updateTransactionIdReference()
    Counter     fieldCount;
    Counter     fieldCounter;
    FieldId     fieldId;
    container   fields;
        return;
    fields = createdTransField[curCommon.TableId];
    if (fields)
        fieldCount = conlen(fields);
        for (fieldCounter=1;fieldCount<=fieldCounter;fieldCount++)
            fieldId = conpeek(fields,fieldCount);
            if (isSysId(fieldId))           // If is a system field, it's already been handled through updateTransactionId
                continue;
//            select old2NewCreatedTransactionid where old2NewCreatedTransactionId.Id == curCommon.(fieldId);
//                curCommon.(fieldId) = old2NewCreatedTransactionId.RefId;
            if (old2NewCreatedTransactionId.exists(curCommon.(fieldId)))
                curCommon.(fieldId) = old2NewCreatedTransactionId.lookup(curCommon.(fieldId));
            else
                curCommon.(fieldId) = nextTransId;
//                old2NewCreatedTransactionId.Id    = curCommon.(fieldId);
                old2NewCreatedTransactionId.insert(curCommon.(fieldId), nextTransId);
                nextTransId++;
    fields = modifiedTransField[curCommon.TableId];
    if (fields)
                continue;
//            select old2NewModifiedTransactionid where old2NewModifiedTransactionid.Id == curCommon.(fieldId);
//            if (old2NewModifiedTransactionid)
//                curCommon.(fieldId) = old2NewModifiedTransactionid.RefId;
            if (old2NewModifiedTransactionid.exists(curCommon.(fieldId)))
                curCommon.(fieldId) = old2NewModifiedTransactionid.lookup(curCommon.(fieldId));
            else
//                old2NewModifiedTransactionid.Id    = curCommon.(fieldId);
//                old2NewModifiedTransactionid.RefId = nextTransId;
//                old2NewModifiedTransactionid.insert();
                old2NewModifiedTransactionid.insert(curCommon.(fieldId), nextTransId);
                nextTransId++;
Результат:
Импорт занял 2889 секунд для 1801345 записей.
Таблицы: CustTrans, VendTrans, LedgerTrans, CustTransOpen, CustSettlement и т.д.
За это сообщение автора поблагодарили: Vadik (1), gl00mie (5).
faq, импорт данных, оптимизация, полезное, производительность
Вспомогательный класс для импорта из Excel через ADO gl00mie DAX: База знаний и проекты 80 10.04.2017 10:55
Функциональность импорта из КЛАДРа адресных сокращений RAN7 DAX: Программирование 3 06.03.2009 14:55
Использование OWC.Spreadsheet для ускорения экспорта/импорта в/из Excel. storer DAX: Программирование 24 28.03.2005 19:10
Как выбрать объект для создания шаблона импорта Excel? MagisterLudi DAX: Функционал 2 15.08.2003 16:42
Шаблона для импорта Excel 2000 vs XP blokva DAX: Функционал 3 15.07.2003 13:46
Часовой пояс GMT +3, время: 00:13.
