Старый 29.05.2008, 17:05   #1
Kashperuk Ivan: EditorScripts.addIns_OpenInAOT - version 2
Источник: http://kashperuk.blogspot.com/2008/0...version-2.html
A long time ago, I posted an editor script for opening objects selected in the editor in AOT (link to that post)
Yesterday, miklenew from AxForum posted an editor script for AX 3.0 that opens a new AOT window with the object currently selected in the Editor, that works a little differently and also allows to open objects based on variable type. You can view the original post here.
Today I modified this code, extending it a bit and adding support for Dynamics AX 4.0 and Dynamics AX 2009 (For version 3.0 use the code posted on AxForum).
public void addIns_OpenInAOT(Editor e)
#AOT
TreeNode treeNode = TreeNode::findNode(e.path());
xRefTmpReferences xRefTmpReferences;
Column nCol = e.columnNo() + 1;
Line nLine = e.currentLineNo() + 1;
treeNode.AOTmakeXref(1);
xRefTmpReferences = xRefCreate::makeTmp(infolog.lastxRef());
select firstonly xRefTmpReferences
order by Column desc
where xRefTmpReferences.line == nLine &&
xRefTmpReferences.Column <span style="color:#808030;">
Kashperuk Ivan: DEV_SysTableBrowser version 2.0 is out! Blog bot DAX Blogs 20 25.10.2007 21:03
Kashperuk Ivan: DEV_CreateNewProject tool version 2.0.0 Blog bot DAX Blogs 0 04.09.2007 01:12
Kashperuk Ivan: AxCreateNewProject version 1.3.2 releasedUpdated... Blog bot DAX Blogs 0 16.03.2007 22:51
Kashperuk Ivan: AxCreateNewProject version 1.3.1 availableI have... Blog bot DAX Blogs 0 08.02.2007 22:31
Kashperuk Ivan: AxCreateNewProject tool Version 1.2I made some a... Blog bot DAX Blogs 0 26.01.2007 05:51
Часовой пояс GMT +3, время: 08:28.
