Старый 12.09.2008, 02:05   #1
Dianne Siebold: AIF Queries & Schemas: A Picture is Worth a Thousand Words
Источник: http://blogs.msdn.com/dsiebold/archi...and-words.aspx
A while back I created this graphic to show the relationship between a document query and the document schema. If you’re new to AIF, this may help you understand the format of the data that flows in and out of AIF through the document services.
When using a document service in AIF, you call a service operation such as SalesOrder.read to read the sales order. When the service operation is called, the service passes this request to the Axd class, in this case AxdSalesOrder. The document class is based on a query, in this case the query is also called AxdSalesOrder. The query defines the schema for the document. So when the sales order data is sent from AX back to the calling system in XML, the structure of the XML matches that of the source query.
This image shows you the XML elements and how they map to the elements in the source query. The document itself is “SalesOrder” while each data source in the query has an “entity” attribute.
Hopefully this elucidates the XML document structure and will help you in troubleshooting.
Dianne Siebold: AIF Services & Locale Blog bot DAX Blogs 0 09.12.2008 11:05
Dianne Siebold: Video About the AIF Services and WCF Blog bot DAX Blogs 0 11.10.2008 07:43
Dianne Siebold: AIF Code Samples Available for Download Blog bot DAX Blogs 0 22.08.2008 09:05
Dianne Siebold: Guide to AIF Documentation Available Blog bot DAX Blogs 0 25.06.2008 06:14
Dianne Siebold: AIF Top Ten Blog bot DAX Blogs 1 22.04.2008 11:19
Часовой пояс GMT +3, время: 03:25.
