Старый 08.10.2008, 10:05   #1
Dynamics AX Sustained Engineering: Dynamics AX 2009 Patching
Источник: http://blogs.technet.com/dynamicsaxs...-patching.aspx
A question that many customers and partners have regarding AX 2009 is how patching is handled for the product. Changes have been made in Dynamics AX 2009 to address some of the concerns that existed with the patching strategy that was in place for Dynamics AX 4.0.
A quick summary of how patching is done in Dynamics AX 4.0:
  • SYS Layer code patched via a layer file for the DIS layer
  • GLS Layer code patched via an .xpo file
There are some positives and negatives to this patching approach which I have summarized here:
Positives:
  • Cumulative layer (DIS) was tested with all fixes included so all fixes work together
  • Application version incremented with each patch allowing users to know exactly what patches were installed
Negatives:
  • Fixes were shipped in a cumulative layer - Difficult to get a single fix out of the layer
  • Larger scope of customization analysis due to the cumulative layer - similar to a Service Pack
  • Lack of detailed fix documentation
  • Over-layering of region-specific code (GLS) due to SYS patches living in the DIS layer
  • Inconsistent patching experience for SYS and GLS code
This feedback was used to make some crucial changes in the design of Dynamics AX 2009 to allow for a more convenient and usable patching approach. For Dynamics AX 2009 individual patches are available for SYS and GLS code. The key change to delivering the individual fix is that Dynamics AX will now allow the import of a signed .xpo file to a particular layer. For a patch to code that resides in the SYS layer a patch would be made that would load an .xpo into the SYP layer. GLS code patches will be made to the GLP layer. This is helpful for multiple reasons. First, the SYP layer is controlled by Microsoft and does not allow others to include code in the layer. This means that only patches released from Microsoft will reside in the layer. At the time of a service pack update, we can also move the axsyp.aod automatically to the old folder for comparison purposes as we know where previously installed patches will reside on the system. The second advantage to patching SYS code in the SYP layer is that any over-layering issues can be avoided. By patching in the proper layer a patch will not overwrite any country-specific functionality that would have expanded on the global code base.
For an application hot fix we ship a package that contains the following:
  • Licenseterms folder
  • Support folder
  • axpatch.exe
  • kbXXXXXX.txt
  • kbXXXXXX-[layer].cab
A patch is installed for Dynamics AX 2009 by clicking on axpatch.exe and following the prompts from the installer. The *.cab file contains the Microsoft signed .xpo as well as an .xml file which directs the installer to the appropriate layer to patch.
The folder named licenseterms contains the license terms used in the installer for each of the supported languages. In the support folder the 24 languages for the patch installer are included as well as necessary files for managing the import of a patch.
The kbXXXXXX.txt file contains the affected objects including methods. This is helpful in initial analysis to determine if the affected object has been modified on your system in any other layer. After the initial analysis the patch can be applied to a test system and the compare tool inside of Dynamics AX can be used to analyze any changes that need to be made to merge the patch into the environment before being deployed on the live system.
Additionally, once an application patch has been applied a new class can be found in the Application Object Tree (AOT) called SysHotFixManifest. This class will contain a method with the KB Article number representing each patch applied to the system. This is done to allow the tracking of patches deployed in AX 2009 as the application version cannot be incremented when using individual patches.
In summary, Dynamics AX 2009 can be patched via a Microsoft signed .xpo file in a specific layer. This enables better tracing of installed patches as well as isolating Microsoft code from customizations and third party applications. The patches installed on an environment can be seen in the SysHotFixManifest class and will appear as methods indicating each KB Article applied.
For additional information on patching Dynamics AX 2009 please see the Dynamics AX 2009 Patching Whitepaper which has been published on PartnerSource\CustomerSource.
PartnerSource
https://mbs.microsoft.com/partnersource/deployment/documentation/whitepapers/AX2009Patching
CustomerSource
https://mbs.microsoft.com/customersource/support/documentation/whitepapers/AX2009Patching
Please feel free to comment with your feedback or any questions regarding this approach.
Thanks for reading and have a great day!
Dynamics AX Sustained Engineering Team
ax4.0, hotfix
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
JOPX: Dynamics AX 2009 - Enterprise Portal link bonanza Blog bot DAX Blogs 0 27.11.2008 01:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Service Pack 1 Released Blog bot DAX Blogs 5 21.11.2008 17:00
Часовой пояс GMT +3, время: 21:58.
