Старый 14.12.2008, 15:05   #1
axaptapedia: Changing Splashscreen
Источник: http://www.axaptapedia.com/Changing_Splashscreen
Summary: New page: In several situations it is useful to customize the client. For example to signal the user that he is using a test system or a client with a different service pack. Per default there is no...
In several situations it is useful to customize the client. For example to signal the user that he is using a test system or a client with a different service pack. Per default there is no way to change the splashscreen. But this can be easily done with a resource editor. There are hundreds of good editors, one of them is [http://www.restuner.com/ Resource Tuner]. Changing the splashscreen is easy:
* Locate the ax32.exe file. By default it will be in C:\Program Files\Microsoft Dynamics\AX50\Client\Bin, or AX40\ , AX30\ directory depending on your version of Dynamics AX.
* Start the resource editor and load the ax32.exe file
* Go to the embedded images and locate the splashscreen
[[Image:Resource.png]]
* Exchange the image with anything you want. If you use Resource Tuner, right client on the image (7511 for AX50) and choose "Save Resource As" to extract the image as BMP on your computer. No you can start customizing the splashscreen with your favorite image manipulation tool. When you have finished your work, right click again on the image and choose "Edit Resource".
[[Image:Resourceexc.png]]
* Save and overwrite the old ax32.exe file with your new one.
* On the next startup you see your splashscreen
[[Category:Axapta architecture]]
Старый 15.12.2008, 01:05   #2
Вроде когда-то слышал, что это нарушает соглашение какое-то.
Правда?
Старый 15.12.2008, 02:03   #3
Alex_KD is offline
Alex_KD
AxAssist
522 / 362 (14) ++++++
Правда?
Ага, где-то в соглашении есть "нельзя менять бинарники".
MICROSOFT SOFTWARE LICENSE TERMS
MICROSOFT DYNAMICS AX 4.0
4. ADDITIONAL LICENSING REQUIREMENTS AND/OR USE RIGHTS.
f. Modification. You may modify the software only as necessary to use it if you received it in source code form or you have licensed tools from Microsoft that allow you to modify the object code form. You agree that Microsoft is not responsible for any problems that result from modifications made by you or a third party or that are caused by third party hardware or software.
6. SCOPE OF LICENSE.
You may only use the software for your internal business purposes. You may not
• work around any technical limitations in the software;
• reverse engineer, decompile or disassemble the software, except and only to the extent that applicable law expressly permits, despite this limitation;
• make more copies of the software than specified in this agreement or allowed by applicable law, despite this limitation;
Но, вообще говоря, ресурсы из почти любого екзешника вытаскиваются и заменяются подобным образом.
Последний раз редактировалось Alex_KD; 15.12.2008 в 02:26.
Старый 15.12.2008, 08:33   #4
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
я думаю, стоит это предупредление добавить на википедию
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
axStart: Best practice for creating/changing sales/purchase & project reports. Blog bot DAX Blogs 0 23.12.2007 17:51
axcoder: AxPath is supported by axaptapedia Blog bot DAX Blogs 0 11.05.2007 10:00
Часовой пояс GMT +3, время: 01:53.
