Старый 10.03.2009, 02:25   #1
mfp: migrax(tm): A new way to do code upgrade.
Источник: http://blogs.msdn.com/mfp/archive/20...e-upgrade.aspx
More Dynamics; one of the Gold Sponsors on Convergence 2009; has just released what I find to be a very interesting product: migrax™. migrax™ can assist in migrating AX solutions from version 3 and version 4 to AX2009.
The approach taken is quite different from the code upgrade tools available in AX. The existing AX code upgrade tools live inside MorphX; and can harvest the benefits of MorphX, such as access to the AOT, Compare tools, BP tools, etc. However; living inside MorphX also induces certain limitations; for example all editing has to go through the AOT modeling API.
migrax™ does it differently. It is an external application. You start by loading your solution as an XPO file. It will be converted to XML and persisted in a database inside migrax™. Using XML techniques migrax™ is able to automatically resolve most code conflicts and produce an XPO file upgraded to Dynamics AX 2009.
migrax™ is capable of solving logical conflicts caused when the standard application (typically in the SYS layer) changes, and the changed element has been customized. migrax™ is by-nature not capable of resolving conceptual conflicts, like conflicting or redundant functionality. Here a set of human eyes is still needed.
One might argue that migrax™ is competing with the standard tool set in MorphX in upgrading code. I have a different perspective. The goal for me is to enable customers and partners to upgrade to Dynamics AX 2009 as seamless as possible. Having a larger tool box is a benefit to everyone.
Make sure to check-out the migrax™ site, and visit More Dynamics at Convergence 2009 in New Orleans.
msdynamicsax: Code Upgrade Tool Enhancements Blog bot DAX Blogs 0 04.04.2008 11:05
mfp: Do you want to write more secure code? Blog bot DAX Blogs 0 26.03.2008 18:05
mfp: Writing less code: The "else" statement Blog bot DAX Blogs 15 25.02.2008 17:54
mfp: Sneak preview - Code Upgrade Enhancements Blog bot DAX Blogs 0 02.03.2007 20:46
mfp: Survey opened: Microsoft Dynamics AX Code Upgrade Estimation Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 14:41.
