Старый 26.10.2009, 00:08   #1
axaptapedia: AIFEnvelopeTool
Источник: http://www.axaptapedia.com/AIFEnvelopeTool
Summary: New page: ==Overview== This tool enable the wrapping of any XML message with an envelope so that it can be processed by the AIF. You specify the input file containing the message to be wrapped, ...
==Overview==
You specify the input file containing the message to be wrapped, where to output the wrapped file and message header detail, then click 'OK' to generate the output file:
[[Image:AIFEnvelopeTool.png]]
==Background==
When a message is received in AX using the Application Integration Framework (AIF), that message must be wrapped in an envelope.
That envelope contains a body (which contains the message) and a header which identifies the message and how it should be handled, eg:
{FC1E887D-F930-4AA3-AC1C-E5851D090463}
MYDOMAIN\MYUSER
CustomerCompany
MyCompanyLEP
readListExchangeRates
This tool will add the wrapping around the 'inbound message' shown above.
==Download==
[http://www.axaptapedia.com/images/2/...velopeTool.xpo AIFEnvelopeTool 1.0]
==Installation==
*Import .xpo file into Dynamics AX.
*Optionally add menu item DEV_XmlAddAIFEnvelope to the Basic/Periodic/Application Integration Framework menu.
*Alternatively open the DEV_XmlAddAIFEnvelope form from the AOT.
==Supported Dynamics AX versions==
*Developed in Dynamics AX 4.0 SP2
* Dynamics AX 2009
[[Category:Development tools]]
[[Category:Tools]]
axaptapedia: Tutorial Password Blog bot DAX Blogs 1 22.05.2009 21:23
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
axcoder: AxPath is supported by axaptapedia Blog bot DAX Blogs 0 11.05.2007 10:00
Часовой пояс GMT +3, время: 22:11.
