Старый 05.02.2010, 21:05   #1
emeadaxsupport: Error “Thread was being aborted” when deploying reporting extensions
Источник: http://blogs.msdn.com/emeadaxsupport...xtensions.aspx
Some time ago we run into problem which did not let us deploy reporting extensions to SQL Reporting Services. Just after building libraries we got the error:
[ThreadAbortException]: Thread was being aborted.
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
at System.Web.HttpApplication.ApplicationStepManager.ResumeSteps(Exception error)
at System.Web.HttpApplication.System.Web.IHttpAsyncHandler.BeginProcessRequest(HttpContext context, AsyncCallback cb, Object extraData)
at System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr)
Because the error was very cryptic it took us a lot of time to find the solution for this problem.
In the end it happened that  although all other components on other machines (AOS, Enterprise portal, etc) were already upgraded to SP1 RU3, we totally forgot to upgrade machine were SQL Reporting Services and Microsoft Dynamics AX 2009 Report Deployments tools were installed. After upgrading first to SP1 and then to RU3 we managed to deploy reports.
Please note if you are running AX 2009 RTM version and also running into issue, it can be that you did not apply KB 957312 (https://mbs.microsoft.com/knowledgeb...&wa=wsignin1.0) on machine were Microsoft Dynamics Ax 2009 Reports Deployments tools were installed.
emeadaxsupport: How to install AX 4.0 Reporting Role with SSRS 2008 Blog bot DAX Blogs 2 23.01.2010 08:02
emeadaxsupport: Error when deploying AX Report to SQL Reporting Server - Client found response type of 'text/html;charset=utf8;' but expected 'text/html' Blog bot DAX Blogs 0 12.01.2010 04:44
emeadaxsupport: Error when deploying ODC files: Development site is not found in the EPParameters table Blog bot DAX Blogs 0 09.01.2010 05:05
emeadaxsupport: Unable to install Dynamics AX 2009 Analysis extensions when the default SQL Server Analysis Server collation is set to Turkish_CI_AS or Turkish_CS_AS Blog bot DAX Blogs 0 22.09.2009 04:06
Arijit Basu: Installing AX 2009 Reporting Extensions in MSSQL 2008 & WIN 2008 Blog bot DAX Blogs 0 27.12.2008 17:05
Часовой пояс GMT +3, время: 04:56.
