Старый 27.05.2010, 01:06   #1
lcash: VM Versions, Expiry
Источник: http://blogs.msdn.com/b/lcash/archiv...ns-expiry.aspx
I’ve had a few questions about the expiry date of VM images. The Refresh 2 image that was sent out last year doesn’t expiry until the 15th of November 2010 so you have a while to use that.
If you are using the Refresh 1 or original RTM image is out of date and if you are at the state that it is shutting down you should use the Refresh 2 image that is on partnersouce and customersource.
The date listed on the customersouce notes that the Refresh 2 images expires on Jun1. This page should be updated in a couple of days to the November 15th 2010.
Cheers
Lachlan
(Original post at http://blogs.msdn.com/lcash)
lcash: Notes on the updated VM posted to Partnersource Blog bot DAX Blogs 0 05.02.2010 08:05
lcash: Hyper-V VM starts going to “Paused-Critical” status Blog bot DAX Blogs 0 15.01.2010 02:09
lcash: Additional disks with Refresh 2 and creating your own VMC or VM configuration Blog bot DAX Blogs 0 19.10.2009 17:05
lcash: unzipping the VM files, external disks not formatted for NTFS Blog bot DAX Blogs 0 04.09.2009 14:05
lcash: Using document handling to add image in Demo VM Blog bot DAX Blogs 0 21.07.2009 10:05
Часовой пояс GMT +3, время: 15:58.
