Старый 31.01.2014, 18:37   #1
Wamr is offline
Wamr
1,737 / 868 (32) +++++++
Записей в блоге: 7
Обновления SQL 2012
У одного клиента возник вопрос о самой свежей версии MS SQL server 2012.
Для меня было открытием, что обновления для него выходят чаще чем для DAX.
Вот тут есть список
Меня заинтересовала вот такой фикс из CU8 (от 20.01.2014):
Consider the following scenario:•You have a database that has the ALLOW_SNAPSHOT_ISOLATION and READ_COMMITTED_SNAPSHOT options enabled in Microsoft SQL Server 2012.
•You have at least three concurrent queries that run against the same table.
•The queries use the (TABLOCK, UPDLOCK) query hint.
•Each query is wrapped in an explicit BEGIN TRAN, but COMMIT TRAN is not executed.
In this scenario, when the first query is committed, one of the other queries will deadlock.
When READ_COMMITTED_SNAPSHOT is enabled along with the query hints TABLOCK and UPDLOCK, the sessions take IX locks on the table. The deadlock occurs when the two concurrent sessions attempt to convert the IX locks to X locks at the same time. If READ_COMMITTED_SNAPSHOT is disabled, the sessions will obtain SIX locks that will not deadlock when converted to X locks. The hotfix addresses this by granting LCK_M_SCH_S locks instead of IX locks when READ_COMMITTED_SNAPSHOT is used with TABLOCK and UPDLOCK hints.
Note This issue also occurs in Microsoft SQL Server 2008 R2. A hotfix for SQL Server 2008 R2 will be released soon.
P.S.
Еще меня порадовало такое замечание:
•We recommend that you test hotfixes before you deploy them in a production environment.
• This cumulative package is intended to correct only the problems that are described in this article. Apply it only to systems that are experiencing these specific problems. The updates in this package may receive additional testing. Therefore, if you are not severely affected by any of these problems, we recommend that you wait for the next SQL Server 2012 service pack that contains the hotfixes in this package.
Последний раз редактировалось Wamr; 31.01.2014 в 18:40.
За это сообщение автора поблагодарили: Logger (5), MikeR (3), Kabardian (2).
Старый 31.01.2014, 20:07   #2
Logger is offline
Logger
3,987 / 3273 (117) ++++++++++
Записей в блоге: 2
Так это стандартное замечание. Его ко всем хотфиксам обычно добавляют.
Типа как в Макдональдсе пишут - "осторожно горячо".
За это сообщение автора поблагодарили: Kabardian (1).
Старый 01.02.2014, 10:54   #3
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
[QUOTE=Wamr;301936]что обновления для него выходят чаще чем для DAX.
Вот тут есть список
QUOTE]
У меня есть стойкое ощущение, что DAX менее флагманский продукт, чем сиквел.
ERP-шек то много сейчас у вендора и NAV, DAX, SL.....
Axapta book for developer
Старый 22.02.2014, 22:00   #4
Wamr is offline
Wamr
Записей в блоге: 7
Еще полезности из пакета обновления SQL
http://blogs.msdn.com/b/axinthefield...-2012-sp1.aspx
а вот и апдейт для SQL Server 2008R2
Cumulative update package 11 for SQL Server 2008 R2 Service Pack 2
и весь список для SQL Server 2008R2
Последний раз редактировалось Wamr; 22.02.2014 в 22:17.
addicted2ax: Dynamics AX 2012 & SQL Server 2008R2: Cross Join vs. Inner Join – Houston we have *NO* Problem Blog bot DAX Blogs 0 20.12.2012 20:11
dynamicsaxbi: Better together: Microsoft Dynamics AX 2012 R2 and SQL Server Power View Blog bot DAX Blogs 0 12.12.2012 13:11
dynamicsaxtraining: Purchase Blog bot DAX Blogs 0 11.03.2012 05:25
Часовой пояс GMT +3, время: 15:46.
