#1 |
kamalblogs: Finding if a node is existing in lower layers Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2010...s-dynamics-ax/
============== Sometime when we were automating our form documentation methodology I had one particular requirement. I had to find if a component exists in the lower layer(Below BUS layer in our case). I tried searching for a way in the standard Ax to figure out. But i was unsuccessful, so at the end I wrote myself a small piece of code that will indicate if a component exists in the lower layer. Here it goes UtilEntryLevel getHighestBelowCurLayer(TreeNode _treeNode){ UtilEntryLevel layer, highestLayer; ; for (layer=UtilEntryLevel::sys; layer < UtilEntryLevel::bus; layer++) { if (SysTreeNode::isNodeInLayer(_treeNode, layer)) { highestLayer = layer; break; } } return highestLayer;} ![]() ![]() Источник: http://kamalblogs.wordpress.com/2010...s-dynamics-ax/
