Старый 11.02.2011, 00:15   #1
25,644 / 848 (80) +++++++
Harish Mohanbabu: Microsoft Dynamics AX 2009 Enterprise Portal - Web part error
Источник: http://harish-m.livejournal.com/31367.html
After we installed Enterprise Portal, when we tried to open for the first time we had following error message -
Web Part Error: A Web Part or Web Form Control on this Page cannot be displayed or imported. The type could not be found or it is not registered as safe.
After spending some time, the issue was found to be 'axwebparts.cab' (under Operations > Solution Management in SharePoint Central Administration site) in wrong retracted status. After deploying the solution, the above error went away.
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
emeadaxsupport: Dynamics AX 2009 Enterprise Portal Web Controls are stored in USR instead of VAR Layer Blog bot DAX Blogs 0 21.09.2010 13:05
Microsoft Dynamics CRM Team Blog: List Web Part for Microsoft Dynamics CRM 4.0: Understanding Connections Blog bot Dynamics CRM: Blogs 0 20.01.2009 02:07
Dynamics AX: Microsoft Dynamics AX Enterprise Portal - Team Blog Blog bot DAX Blogs 0 23.07.2008 19:05
Часовой пояс GMT +3, время: 13:17.
