#1 |
dax-lessons: Sort a container [using X++ , Dynamics AX]
Источник: http://dynamicsaxgyan.wordpress.com/...x-dynamics-ax/
============== Friends, Recently I was in need of sorting the elements in the container and use them . I am not sure how far this code is helpful to you guys. Below code will help to sort the elements in the … Continue reading → ![]() X++: static void SR_sortContainer(Args _args) { container con = [5,1,2,'Sumit Loya',9, 'Ashish singh', NoYes::No]; str temp1; str temp2; int i; int j; container sorCon; ; sorCon = con; // Sort the container for (i = 1; i <= conlen(sorCon); i++) { for (j = i + 1; j <= conlen(sorCon); j++) { temp1 = conpeek(sorCon, j); temp2 = conpeek(sorCon, i); if (temp1 < temp2) { sorCon = condel(sorCon, j, 1); sorCon = conins(sorCon, j, temp2); sorCon = condel(sorCon, i, 1); sorCon = conins(sorCon, i, temp1); } } } conview(sorCon); }
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Последний раз редактировалось Poleax; 22.04.2011 в 10:45. |
