Старый 03.05.2011, 06:15   #1
How to find your object in AOT projects
Источник: http://alexvoy.blogspot.com/2011/05/...-projects.html
This is a small but precious tool for AX developing.
Have you ever tried to find in which projects your objects are included? Yes, I have... Not so easy to search and look into each project.
Now, it is just a question of one click: this mighty LC Project Search will make the life easier. And good news, it is free. So, profit and enjoy!
There are three xpo-files with appropriate versions for AX 4.0, 2009, and 2012. (I have tested 2009 one). You can import it, then launch with the menu item, and this is ready to go.
Just type the name of any object you're looking for, optionally, you can choose the type of it, then press Search. Be patient, it takes some time to populate the result table.
Now, all projects contain the object are here.
Take a look at Loncar Technologies company web site: there you can get some more.
xplusplus: Dynamics AX Application Object Tree (AOT) Blog bot DAX Blogs 0 25.11.2010 18:11
emeadaxsupport: Renaming an AOT object in Dynamics AX 2009 that is under source control with Team Foundation Server Blog bot DAX Blogs 0 06.10.2009 02:05
Dynamics AX FAQ: How to find an AOT object by its property? Blog bot DAX Blogs 2 07.11.2008 12:54
Dynamics AX FAQ: How to get the top most application layer of an AOT object? Blog bot DAX Blogs 0 19.10.2008 18:05
axStart: How to find line of code with a question mark in your AOT. Blog bot DAX Blogs 0 16.04.2008 22:05
Часовой пояс GMT +3, время: 18:26.
