		#1 |
			axinthefield: Too Much Database Logging in Dynamics AX
			Источник: http://blogs.msdn.com/b/axinthefield...namics-ax.aspx
			============== One of the best features in Dynamics AX is database logging. While this gives you a great audit trail for tracking changes in your system, this can actually lead to a performance problem in your Dynamics AX system. There are essentially two major performance issues that come up with database logging. The first is that it can make the AX kernel ignore all set based operations on that table. So, all X++ code such as UPDATE_RECORDSET will become a row based operation causing multiple round trips to the database. Code such as the following that might update 1000 employee records giving everyone a 10% raise in 1 statement would actually cause 1000 trips to the database to update each record if UPDATE logging was enabled on this table MyTable myTableBuffer; ; update_recordset myTableBuffer setting field1 = field1 * 1.10; The second major issue is the amount of writes that potentially are caused in the database. The hard part about this is determining when we have too much. Performance Analyzer for Microsoft Dynamics makes this task fairly easy to identify. One of the DMVs that we collect data from is sys.dm_db_index_usage_stats. With this DMV we can determine the amount of writes that occur on a table in the Dynamics AX database. The following query shows this activity: SELECT TABLE_NAME, CASE WHEN ( SUM(USER_UPDATES + USER_SEEKS + USER_SCANS + USER_LOOKUPS) = 0 ) THEN NULL ELSE ( CAST(SUM(USER_SEEKS + USER_SCANS + USER_LOOKUPS) AS DECIMAL) / CAST(SUM(USER_UPDATES + USER_SEEKS + USER_SCANS + USER_LOOKUPS) AS DECIMAL) ) END AS RatioOfReads, CASE WHEN ( SUM(USER_UPDATES + USER_SEEKS + USER_SCANS + USER_LOOKUPS) = 0 ) THEN NULL ELSE ( CAST(SUM(USER_UPDATES) AS DECIMAL) / CAST(SUM(USER_UPDATES + USER_SEEKS + USER_SCANS + USER_LOOKUPS) AS DECIMAL) ) END AS RatioOfWrites, SUM(USER_SEEKS + USER_SCANS + USER_LOOKUPS) AS TotalReadOperations, SUM(USER_UPDATES) AS TotalWriteOperations, SUM(USER_UPDATES + USER_SEEKS + USER_SCANS + USER_LOOKUPS) AS TotalOperations FROM INDEX_STATS_CURR_VW /*sys.dm_db_index_usage_stats*/ GROUP BY TABLE_NAME --order by TotalOperations desc --order by TotalReadOperations desc ORDER BY TotalWriteOperations DESC The results will look as follows: TABLE_NAME RatioOfReads RatioOfWrites TotalReadOperations TotalWriteOperations TotalOperations REQTRANS 0.4712597612623479424 0.5287402387376520575 1568631 1759960 3328591 SYSDATABASELOG 0.2968271219786954271 0.7031728780213045728 299327 709095 1008422 SALESSHIPPINGSTAT 0.1857588421387402567 0.8142411578612597432 133172 583736 716908 SMMTRANSLOG 0.5236542880462582721 0.4763457119537417278 326566 297063 623629 INVENTSUMLOGTTS 0.2288269604666234607 0.7711730395333765392 79443 267732 347175 LEDGERTRANS 0.4046390537009612028 0.5953609462990387971 171588 252464 424052 INVENTTRANS 0.9204778317203861103 0.0795221682796138896 2215858 191433 2407291 INVENTSUMDELTA 0.2312710628890821230 0.7687289371109178769 53459 177694 231153 NUMBERSEQUENCELIST 0.3341698307533857008 0.6658301692466142991 86955 173257 260212 INTERCOMPANYINVENTDIM 0.2038198652382568229 0.7961801347617431770 42046 164244 206290 In this example, you can see that the 2nd most written too table in the database is SYSDATABASELOG. If this table is in the top 10 written too tables in your system, then logging should be reviewed. Some good practices are:
 Be cautious when setting up logging in Dynamics AX. Ensure there is a real business need for the logging that is configured and that the data will actually be reviewed or you may cause a performance issue. Источник: http://blogs.msdn.com/b/axinthefield...namics-ax.aspx
	Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору.  |
