Старый 09.09.2011, 01:13   #1
25,644 / 848 (80) +++++++
emeadaxsupport: A CLR error occurred while invoking the scheduling engine
Источник: http://blogs.msdn.com/b/emeadaxsuppo...ng-engine.aspx
We came across this issue recently. When running the Production Job scheduling process you experience error "A CLR error occurred while invoking the scheduling engine." and the exception details look like this
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation ---> Microsoft.Dynamics.AX.ManagedInterop.ContainerNotValidException
The Microsoft Dynamics container being referenced is not valid at Microsoft.Dynamics.AX.ManagedInterop.Container.get_Count()
The issue in this was caused by the AOS Server configuration option "Enable the hot-swapping of assemblies for each development session" being enabled on the server. This option should NOT be activated on production environments.Disabling th eoption resolved the issue
However there are other causes of production job scheduling issues, and this are mentioned in the Microsoft Dynamics AX 2012 Release Notes. One of them being: "The resource scheduling engine uses a hard-coded resource name for jobs that do not include a resource or calendar. The hard-coded resource name is "EmptyRes". This hard-coded name might conflict with actual resource names. There is no workaround for this issue." The solution for this is to create a new resource: "emptyres".
--author:Pere Turegano--editor:Anup Shah--date:08/Sep/2011
emeadaxsupport: Finding the X++ call stack that caused a crash Blog bot DAX Blogs 2 14.01.2020 13:20
Microsoft Dynamics CRM Team Blog: Report Scheduling with Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 07.01.2011 20:11
emeadaxsupport: Special Permission Settings in Dynamics AX 2009 Blog bot DAX Blogs 0 02.09.2010 22:05
emeadaxsupport: Working with CLR Exceptions in Dynamics AX X++ code Blog bot DAX Blogs 0 22.07.2010 19:06
Arijit Basu: Microsoft Dynamics AX CLR Interop Blog bot DAX Blogs 0 07.10.2007 01:03
Часовой пояс GMT +3, время: 06:57.
