Старый 03.10.2011, 18:11   #1
axaptacorner: License is not exist for language en-in
Источник: http://axaptacorner.blogspot.com/201...age-en-in.html
ERROR-LICENSE IS NOT EXIST FOR LANGUAGE EN-IN
SOLUTION- This is commen error when we create new instanse and upload licence in different language
to license language. following steps help u to find out right solution
1.open administrator tools
2.choose Microsoft Dynamics Ax configuration utility
3.write language=en-in in configuration command to run at kernal startup(where en-in is license language)
4.but once u login put right option (language) from tools->option->language
5.and now clean kernal startup
Keep on right coding!!!!!!!!
axaptacorner: Not enough rights to use table 'Signature log' (SIGSignatureLog) Blog bot DAX Blogs 0 24.07.2011 14:14
Dynamics AX Sustained Engineering: Advance Holder functionality not available without Finance II license Blog bot DAX Blogs 0 28.09.2010 22:05
emeadaxsupport: The Dynamics AX 2009 AOS does not start with "The license information can not be decoded" error Blog bot DAX Blogs 0 22.09.2010 23:05
emeadaxsupport: Warning when loading license file - License value for ID 2024 has not been created (or License value for ID 2025 has not been created) Blog bot DAX Blogs 0 12.01.2010 04:44
Часовой пояс GMT +3, время: 23:43.
