Старый 17.10.2011, 20:11   #1
dynamicsaxtraining: Update assembly configuration file on the fly (from code)
Источник: http://www.dynamicsaxtraining.com/kn...-fly-from-code
The following code could be used to update the DLL configuration file from the code. It could be useful for example when User changes some parameter in Dynamics AX and .NET assemble should use other instance of external application.
//_webReferenceName - the name of webReference (AOT\References)
//_endPoint - the new address
server static void updateAppConfig(str _webReferenceName, str _endPoint)
#define.Ax32Serv('Ax32Serv.config')
#define.endPointTag('endpoint')
#define.addressAttribute('address')
SysReference sysReference;
FilePath serverConfigFile;
Microsoft.Dynamics.IntegrationFramework.WebService.AppDomainCache appDomainCache;
XMLDocument xmlDocument;
XMLNodeList xmlNodeList;
XmlElement xmlElement;
//Create SysReference object
new InteropPermission(InteropKind::ClrInterop).assert();
sysReference = SysReference::newFromReferenceName(_webReferenceName);
if (sysReference == null)
throw error(strfmt("Referenct '%1' was not found", _webReferenceName));
CodeAccessPermission::revertAssert();
//Configure
serverConfigFile = xinfo::directory(DirectoryType::Bin) + #Ax32Serv;
new FileIOPermission(serverConfigFile, SysDataExpImp::readWrite2Mode(ReadWrite::read)).assert();
xmlDocument = new XMLDocument();
xmlDocument.load(serverConfigFile);
xmlNodeList = xmlDocument.getElementsByTagName(#endPointTag);
xmlElement = xmlNodeList.nextNode();
while (xmlElement)
xmlElement.setAttribute(#addressAttribute, _endPoint);
//BP Deviation documented
new FileIOPermission(serverConfigFile, SysDataExpImp::readWrite2Mode(ReadWrite::Write)).assert();
xmlDocument.save(serverConfigFile);
//Reset application cashe - update end point adress
appDomainCache = Microsoft.Dynamics.IntegrationFramework.WebService.AppDomainCache::get_Instance();
if (appDomainCache)
appDomainCache.Remove('LaserNet');
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 4 Blog bot Dynamics CRM: Blogs 0 24.09.2011 01:16
Microsoft Dynamics CRM Team Blog: Importing two or more entities from a Single File Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 21:56.
