Старый 26.11.2011, 12:11   #1
doens.be: How to run a Microsoft Ax 2012 Hyper-V on VirtualBox (Enterpris Portal Problem)
Источник: http://www.doens.be/2011/11/how-to-r...ortal-problem/
In my previous post I described how to run the standard Microsoft Ax 2012 Hyper-V VPC on your regular Windows Client with VirtualBox. There was one thing I forgot to mention, when you want to use the Enterprise Portal (and you probably will) you need to adjust the windows hosts-file on the VPC.
How:
  • Just open Notepad and open ‘C:\Windows\System32\drivers\etc\Hosts’
  • Add a line  containing ’127.0.0.1              dynamicsax.contoso.com ‘
Now the file should look like this:
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a ‘#’ symbol.
# For example:
#      102.54.94.97     rhino.acme.com          # source server
#       38.25.63.10     x.acme.com              # x client host
# localhost name resolution is handled within DNS itself.
#    127.0.0.1       localhost
#    ::1             localhost
ukax: AX 2012 Training content available on CustomerSource Blog bot DAX Blogs 0 09.09.2011 23:12
Solutions Monkey: Microsoft Dynamics AX 2012 Virtual Launch Event Blog bot DAX Blogs 0 01.09.2011 07:13
How to Write Data Upgrade Scripts for Microsoft Dynamics AX 2012 Vadik DAX: База знаний и проекты 11 31.07.2011 19:03
dynamics-ax: Microsoft Dynamics AX 2012 and the importance of PowerPivot Blog bot DAX Blogs 0 17.02.2011 21:11
Часовой пояс GMT +3, время: 07:06.
