#1 |
sumitsaxfactor: Find Active Dimensions for a Legal Entity [Ax2012]
Источник: http://sumitsaxfactor.wordpress.com/...entity-ax2012/
============== This article focuses on getting the active dimensions for a Legal Entity. In Ax 2009, we could get the number of dimensions by using the enumCnt method on SysDimension enum and get the count. Here it is not that straight forward. Following job will help you in getting the count and display their names; staticvoid getActiveFinancialDimensions(Args _args) { DimensionAttributeSetItem dimAttrSetItem; // Contains the number of dimensions active for a account structure ledger DimensionAttribute dimAttr; // Contains the financial dimensions records DimensionEnumeration dimensionSetId; //Record id for table that contains active dimensions for current ledger int dimAttrCount; //Get the record Id (dimension set id) for current ledger to find active dimensions dimensionSetId = DimensionCache::getDimensionAttributeSetForLedger(); //Find the count of active dimensions for current ledger except main account selectcount(RecId) from dimAttr where dimAttr.Type != DimensionAttributeType::MainAccount join RecId from dimAttrSetItem where dimAttrSetItem.DimensionAttribute == dimAttr.RecId && dimAttrSetItem.DimensionAttributeSet == dimensionSetId; info(strFmt("Total active financial dimensions for current legal entity: %1", dimAttr.RecId)); //Find all the active dimensions for current ledger except main account and display them whileselect * from dimAttr orderby Name where dimAttr.Type != DimensionAttributeType::MainAccount join RecId from dimAttrSetItem where dimAttrSetItem.DimensionAttribute == dimAttr.RecId && dimAttrSetItem.DimensionAttributeSet == dimensionSetId { info(dimAttr.Name); } } ![]() Источник: http://sumitsaxfactor.wordpress.com/...entity-ax2012/
