Старый 20.12.2011, 19:11   #1
palleagermark: Odd CIL compilation issue
Источник: http://palleagermark.blogspot.com/20...ion-issue.html
I'd really like some input on this article, if anyone has experienced something similar.
I had a couple of CIL compilation errors today in an imported model. The errors all pertained to a new field that was added to a couple of tables. After setting a random LegacyId for the field, I was able to do a successful CIL compilation, and I was also able to compile successfully after removing the LegacyId again.
I don't know if it was the LegacyId change that did the trick, or just the fact that I made a change to the tables.
Please let me know if you have had similar issues and what ideas you may have to fix them.
(And of course we did, without luck, try all the usual stuff, restarting AOS'es, recompiling X++ etc)
X++: .NET Interop to X++ When X++ Runs as CIL Blog bot DAX Blogs 0 21.09.2011 05:12
axdaily: X++ can be compiled to CIL in AX 2012 Blog bot DAX Blogs 0 23.04.2011 07:11
East Ocean - Technical: CRM outlook client - popup blocker issue Blog bot Dynamics CRM: Blogs 0 09.02.2011 10:11
palleagermark: Annoying bug in AX 2009 Intercompany Sales Order Blog bot DAX Blogs 0 21.01.2010 11:05
Kashperuk Ivan: SysCompilerTarget - compiling X++ code without showing the compilation window Blog bot DAX Blogs 0 24.11.2009 15:05
Часовой пояс GMT +3, время: 15:00.
