Старый 22.02.2012, 10:11   #1
doens.be: Ax2009 Event Processing Error
Источник: http://www.doens.be/2012/02/ax2009-e...cessing-error/
I have a customer that gets a error every time the EventJobCUD-batch (Change Based Events) runs. They got the following error:
After some reseach I found out that when 2 fields are changed at the same time, you go several times through the listChangedFieldsEnumerator (location \Classes\EventProcessorCUD\processUpdate)
1 2 3 4 5 6 7 8 9 while (listChangedFieldsEnumerator.moveNext()) { // In this simple case we use the new and the original changed field value as // recorded at event detection time: [thisFieldId, changedFieldValue, origChangedFieldValue] = listChangedFieldsEnumerator.current(); if (rule.AlertFieldId == thisFieldId) break; }
The code underneed simulates the same situation in a small job:
1 2 3 4 5 6 7 8 9 static void Job5(Args _args) { anytype any; ; any = ABC::A; // next line will throw a error any = BatchStatus::Canceled; }
And here we get the basic same error “Error executing code: Wrong argument types in variable assignment.”
I modified the code so the anytype is assigned only when the field is correct:
1 2 3 4 5 6 7 8 9 10 11 12 while (listChangedFieldsEnumerator.moveNext()) { // In this simple case we use the new and the original changed field value as // recorded at event detection time: thisFieldId = conpeek(listChangedFieldsEnumerator.current(), 1); if (rule.AlertFieldId == thisFieldId) { [thisFieldId, changedFieldValue, origChangedFieldValue] = listChangedFieldsEnumerator.current(); break; } }
emeadaxsupport: Error during processing of 'AX_CompanyName' report parameter. (rsReportParameterProcessingError) Blog bot DAX Blogs 1 11.04.2011 18:56
emeadaxsupport: How batch processing works under the hood AX2009 Blog bot DAX Blogs 0 22.02.2011 12:11
Часовой пояс GMT +3, время: 10:33.
