Старый 05.03.2012, 18:11   #1
25,644 / 848 (80) +++++++
palleagermark: AX 2012 upgrade tip for lazy idiots like me
Источник: http://palleagermark.blogspot.com/20...zy-idiots.html
I didn't read the upgrade material carefully enough, and imported the upgrade framework to my AX 2009 application, before activating multisite in all companies. Now there's an issue with one of the tables of the framework, preventing me from activating multisite.
At this point I could of course uninstall the upgrade framework again, but my laziness is in the way of that solution.
Adding the table to the list of tables the multisite activation wizard shouldn't concern itself with seems to fix the problem:
Use this tip at your own risk.
I'd however like to consider myself a bit excused, when the upgrade guide contains the following statement:
emeadaxsupport: Writing Data Upgrade Scripts Part 1: Understanding the components of the process Blog bot DAX Blogs 0 10.02.2012 05:16
palleagermark: Microsoft Dynamics AX 2012 White Papers: Code Upgrade Blog bot DAX Blogs 0 11.04.2011 19:11
Часовой пояс GMT +3, время: 15:33.
