Старый 20.03.2012, 19:11   #1
emeadaxsupport: Dynamics AX 2012 Prerequisite Check Utility and SQL Server cluster
Источник: http://blogs.msdn.com/b/axsupport/ar...r-cluster.aspx
You may wonder why you’re getting an error that there’s no SQL Server instance available when you run the Dynamics AX 2012 Prerequisite Check Utility on active SQL Server cluster node.
Why does this happen? The Dynamics AX 2012 Prerequisite Check Utility is getting list of all services which names are equal to MSSQLSERVER or start with MSSQL$. Each found service is prefixed with local machine name. As SQL Server cluster has its own network name, it cannot be recognized by the Dynamics AX 2012 Prerequisite Check Utility and that why you always get this error.
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting: How to run reports that executes longer than 10 minutes Blog bot DAX Blogs 0 25.01.2012 10:11
dynamics-ax: Microsoft Dynamics AX 2012 - System Architecture Overview Blog bot DAX Blogs 0 26.05.2011 02:11
fed: Tracing in Dynamics AX 4 and 2009 Blog bot DAX Blogs 0 10.03.2010 20:05
Dynamics Mobile: Dynamics AX Mobile 1.5 SSIS Package Failure when using SQL Server collation Danish_Norwegian_CI_AS Blog bot DAX Blogs 0 17.07.2009 00:06
Часовой пояс GMT +3, время: 22:48.
