Старый 11.05.2012, 18:11   #1
dax-lessons: Get underlying SQL query using getSQLStatement [Dynamics AX 2012]
Источник: http://dynamicsaxgyan.wordpress.com/...amics-ax-2012/
Friends, To get the underlying SQL query or statement from the X++ query, use getSQLStatement method. getSQLStatement is a new method that has been introduced in tables in AX 2012. The X++ select has been extended with the generateonly command that instructs the underlying data access framework to generate the SQL query without actually executing [...]
За это сообщение автора поблагодарили: Logger (1), Ace of Database (2).
generateonly, getsqlstatement
ukax: Get on the “Inside” with our Inside Microsoft Dynamics AX 2012 Blog and Video Series! Blog bot DAX Blogs 0 16.09.2011 22:11
dax-lessons: SysLookupMultiSelectCtrl in Dynamics AX 6.0 [AX 2012, X++] Blog bot DAX Blogs 0 08.06.2011 21:11
dax-lessons: Handling RecIds in SQL Server [Dynamics AX] Blog bot DAX Blogs 0 15.04.2011 20:12
Часовой пояс GMT +3, время: 03:02.
