Старый 28.06.2012, 18:11   #1
25,644 / 848 (80) +++++++
palleagermark: Quick warning about the fill utility
Источник: http://palleagermark.blogspot.com/20...l-utility.html
I have reported some issues with the fill utility to Microsoft support, and apparently the to tool has a severe bug if you try to update fields from a datasource that is not the main datasource of the form you called it from.
If you attempt to use the fill utility in a form to change a field that is not from the main datasource, data in fields from the main data source is updated in stead.
This is unfortunately a bug that the product team will not fix. If you contact Microsoft support with a reference to case reference number 297616, they'll be able to provide you with code that disables the fill utility when called from a non-main datasource.
emeadaxsupport: 4. Solving Fill Utility errors on Microsoft Dynamics AX 2012 - Error executing code: Wrong argument types for comparison (another scenario) Blog bot DAX Blogs 2 08.02.2012 09:21
emeadaxsupport: 3. Solving Fill Utility errors on Microsoft Dynamics AX 2012 - Error executing code: Wrong argument types for comparison Blog bot DAX Blogs 1 08.02.2012 08:53
emeadaxsupport: Fill Utility incorrectly updates a field that is not in the field list of the main datasource Blog bot DAX Blogs 0 27.01.2012 01:12
axinthefield: Update multiple records with 'Fill Utility' Blog bot DAX Blogs 0 21.06.2011 19:11
Dynamics AX Sustained Engineering: Fill Utility incorrectly updating a field in a form datasource Blog bot DAX Blogs 1 27.05.2010 23:05
Часовой пояс GMT +3, время: 04:06.
