Старый 06.11.2012, 15:11   #1
Malaysia: Building a query object
Источник: http://axmas.blogspot.com/2012/11/bu...ry-object.html
class ProjTableQuery
static void main(Args _args)
Query query;
QueryBuildDataSource qbds1;
QueryBuildDataSource qbds2;
QueryBuildRange qbr1;
QueryBuildRange qbr2;
QueryRun queryRun;
ProjTable projTable;
query = new Query();
qbds1 = query.addDataSource(tableNum(ProjTable));
qbds1.addSortField(fieldNum(ProjTable, Name), SortOrder::Ascending);
qbr1 = qbds1.addRange(fieldNum(ProjTable,Type));
qbr1.value(queryValue(ProjType::FixedPrice));
qbr2 = qbds1.addRange(fieldNum(ProjTable,ProjId));
qbr2.value(queryValue('2') + '*');
qbds2 = qbds1.addDataSource(tableNum(ProjEmplTrans));
qbds2.relations(true);
qbds2.joinMode(JoinMode::ExistsJoin);
while (queryRun.next())
projTable = queryRun.get(tableNum(ProjTable));
info(strFmt( "%1, %2, %3", projTable.ProjId, projTable.Name, projTable.Type));
daxmusings: Query Object Datasource Linking Blog bot DAX Blogs 0 14.10.2011 11:11
AIF: OData Query Service Blog bot DAX Blogs 0 24.08.2011 09:11
Dynamics AX Sustained Engineering: Performance issue on Query Object when using Outer Join with more than one Child Table Blog bot DAX Blogs 0 21.12.2010 04:13
Malaysia: Who Modified my Object Blog bot DAX Blogs 0 09.07.2009 02:05
palleagermark: Shortcut to the query object of a form data source Blog bot DAX Blogs 1 07.01.2009 18:33
Часовой пояс GMT +3, время: 00:02.
