Старый 27.11.2012, 21:11   #1
ax-erp: Editing class method without opening the class
Источник: http://microsoft-dynamics-ax-erp.blo...t-opening.html
Hi Hema.,
I've done the same in a form...
Check this code it might be useful....
static void addingcodeatruntime(Args _args)
TreeNode treeNode;
#AOT
str oldsource;
str newsource;
str LineString;
int pos;
container con;
int childCount;
TreeNode = TreeNode::findNode(#FormsPath + "\\Form1"); // "Form1" --
Form Name
treeNode = treeNode.AOTfindChild("Designs"); //Designs Node
treeNode = treeNode.AOTfindChild("Design");
treeNode = treeNode.AOTfindChild("[Tab:Tab2]");
treeNode = treeNode.AOTfindChild("[TabPage:TabPage]");
treeNode = treeNode.AOTfindChild("[ButtonGroup:ButtonGroup]");
treeNode = treeNode.AOTfindChild("CommandButton:CommandButton");
treeNode = treeNode.AOTfindChild("Methods");
treeNode = treeNode.AOTfindChild("clicked");
oldsource = treeNode.AOTgetSource();
con = str2con(oldsource, "\n");
LineString = conpeek(con,5);
pos = strscan(oldsource,LineString,1,strlen(oldsource));
pos += strlen(LineString);
newSource = strins(oldsource," \n \\Diwakar ",pos); //new line to be
inserted
treeNode.AOTsetSource(newsource);
treeNode.AOTcompile(1);
treeNode.AOTsave();
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
ax-erp: SysQueryRangeUtil class - use method name as query criteria Blog bot DAX Blogs 0 13.06.2012 22:11
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Часовой пояс GMT +3, время: 07:36.
