Старый 12.04.2013, 00:15   #1
emeadaxsupport: Filtering in foreign curreny revaluation form for reviewed transactions does not work for other languages than english
Источник: http://blogs.msdn.com/b/axsupport/ar...n-english.aspx
If you log into AX Dynamics 2012 and in the foreign curreny revaluation(exchange adjustment) in another language than English and wish to filter on reviewed and non-reviewed transactions the filter is not executed. This applies both for Accounts Receivable and Accounts Payable
For example, here is an example in Swedish language.Whether you select ‘Inte granskad’(not reviewed) or ‘Granskat’(reviewed) for a reviewed transaction the results are the same
The problem is located in form ‘VendExchRateAdustment. Specifically the executeQuery method on the 'VendExchRateAdjustment' datasource
In here the values for the selection criteria are hardcoded in English with the values 'All', 'Not reviewed' etc
The issue can be resolved by filtering on the enumerated values instead, as on the screenshot below
The same solution can be used on the Accounts Receivable side
The issue is registered with Development for correction in an upcoming service release
emeadaxsupport: How to perform foreign currency revaluation in Consolidation company to satisfy reporting requirements Blog bot DAX Blogs 0 16.10.2012 22:11
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
dynamicsaxtraining: Paying a Vendor Blog bot DAX Blogs 0 22.03.2012 22:11
dynamicsaxtraining: Purchase Blog bot DAX Blogs 0 11.03.2012 05:25
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 23:38.
