Старый 20.08.2013, 21:11   #1
emeadaxsupport: Quick Tip: Testing another country's functionality
Источник: http://blogs.msdn.com/b/axsupport/ar...tionality.aspx
At times you might need to test a certain country's features in Microsoft Dynamics AX 2012- For example, you might want to test Belgian features, but the problem is you don't have a Belgian company
To ensure that you can test Belgian or any other country's features, the principle is that you must have the country code defined in the AX legal entity's country code
For example if you use our demodata and go to the company CEEI(Contoso Italy), normally it will not have any financial transactions as standard(a prerquisite to be able to define the primary legal entity) and you can therefore change the country code on the primary legal entity from 'ITA" to 'BEL'. After this exit AX, and reenter and you can see you will have Belgian(or any other) country features enabled for this legal entity
emeadaxsupport: Quick tip - Unretrieved value in a field in a form Blog bot DAX Blogs 0 09.08.2013 16:11
emeadaxsupport: Microsoft Dynamics AX2012 and country/region settings Blog bot DAX Blogs 0 20.12.2012 01:11
emeadaxsupport: Microsoft BizTalK Server 2010 passes compatibility testing with Microsoft Dynamics AX 2009 SP1 Blog bot DAX Blogs 0 30.09.2011 01:19
Microsoft Dynamics CRM Team Blog: Tip o’ the Day: Quick Codeless Auditing Tool Blog bot Dynamics CRM: Blogs 0 17.08.2010 22:06
Microsoft Dynamics CRM Team Blog: Quick Tip: Passing CRM Form values to an IFrame Blog bot Dynamics CRM: Blogs 0 12.09.2008 02:05
Часовой пояс GMT +3, время: 08:27.
