Старый 11.07.2008, 00:05   #1
Kashperuk Ivan: Microsoft Dynamics AX 2009 Keyboard shortcuts
Источник: http://kashperuk.blogspot.com/2008/0...-keyboard.html
A whole lot of new and handy shortcuts have been introduced in Microsoft Dynamics AX 2009. To name just a few, that are very important for developers:
Ctrl+Shift+P opens the Projects
Ctrl+Shift+I (from AOT or projects) opens the import project window, etc.
Alt+F1 will return you to the main Dynamics AX window (especially useful for those fond of Tabax)
A fellow tester from Dynamics AX Client team, David Kidder, created a document containing the shortcuts available, grouping them according to where they are used in the application.
One thing I would like to highlight is that you don't need to work for Microsoft to create this list. You can get the list of all available shortcuts in the system by launching the client (Ax32.exe) with the -internal=GENERATEKEYHELP command line argument. The xml file with the shortcuts, AxKeyDump.xml, will be placed into the Client\Bin folder of Dynamics AX.
It is an extremely useful document, and I suggest everyone prints it out and hangs it by their desk.
The download link can be found below:
AX 2009 Keyboard Shortcuts.docx
Warning: The file is in Microsoft Word 2007 format, but I am sure all of you have that (or the converter) by now.
Старый 18.12.2013, 17:42   #2
Кхм, кхм, а этого файлика случаем не завалялось у кого-нибудь?
Старый 18.12.2013, 17:51   #3
Slava Chernenko is offline
Slava Chernenko
34 / 15 (0) ++
Этот?
http://blogs.msdn.com/cfs-filesystem...Shortcuts.docx
Старый 18.12.2013, 17:56   #4
Сообщение от Slava Chernenko Посмотреть сообщение
Оно, спасибо Слава, а с какого это блога?
Старый 18.12.2013, 18:17   #5
Slava Chernenko
34 / 15 (0) ++
Я не всматривался - первая ссылка с гугла
https://www.google.dk/search?q=AX+20...Shortcuts.docx
За что тебя на гугле забанили?
Старый 18.12.2013, 18:24   #6
Видимо как раз за то, что у меня ссылка битая была на мой домен, который я давно закрыл...
JOPX: Musings about Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 12.06.2008 23:06
Kashperuk Ivan: Microsoft Dynamics AX 2009 CTP3 release is available on PartnerSource Blog bot DAX Blogs 35 10.04.2008 20:05
Сергей Герасимов: Что нового в Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 16.01.2007 11:00
Часовой пояс GMT +3, время: 07:56.
