Старый 06.05.2014, 08:12   #1
mscrmblog: CRM 2011 – Show Time Field Only
Источник: http://mscrmblog.net/2014/05/06/crm-...me-field-only/
I had a requirement to Show only Time portion of the date field in CRM as we had to schedule classes and the dates weren’t relevant just the times.
Here’s the function I’ve setup to hide the date portion of the field. unfortunately we’ve had to hide it using DOM manipulation as there is no way using the CRM SDK.
function HideDateField(fieldName, showTimeOnly) { var dateField = document.getElementById(fieldName); if (dateField != null) { if (showTimeOnly == true) { dateField.childNodes[1].childNodes[0].childNodes[0].style.display = "none"; dateField.childNodes[1].childNodes[0].childNodes[1].style.display = "none"; dateField.childNodes[1].childNodes[0].childNodes[2].style.display = "none"; dateField.childNodes[1].childNodes[0].childNodes[3].style.display = "none"; } else { dateField.style.display = "none"; } }}It’s a bit of a hack but it works. Tested with UR16.
Старый 28.05.2014, 18:15   #2
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Я бы использовал числовой тип данных с форматом "Длительность". Эффект будет тот же.
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 14 Blog bot Dynamics CRM: Blogs 0 12.07.2013 07:13
Часовой пояс GMT +3, время: 00:38.
