Старый 01.09.2014, 14:11   #1
emeadaxsupport: Microsoft Dynamics AX general performance analysis scripts page 8
Источник: http://blogs.msdn.com/b/axsupport/ar...ts-page-8.aspx
This is page 8 of 8 of the general performance analysis scripts online for the Performance Analyser 1.20 tool. See page 1 for the introduction. Use the links in the table below to navigate between pages.
- General analysisAnalyse SQL ConfigurationPage 1Analyse SQL IndexesPage 2Analyse SQL QueriesPage 3Analyse BlockingPage 4Baseline - benchmark queriesPage 5- AX SpecificAnalyse AX ConfigurationPage 6Analyse AX IndexesPage 7Analyse AX QueriesPage 8Analyse AX Queries
AX_LONG_RUNNING_QUERY_TRACE
HIDDEN_SCANS_QUERIES
OPTION_FAST_QUERIES
USER_SCANS_QUERY
-- AX_LONG_RUNNING_QUERY_TRACE
-- Find long running queries from Dynamics AX with source code
-- requires client tracing being enabled on the AOS configuration
SELECT TOP 100 [CREATED_DATETIME],[DATABASE_NAME],[ROW_NUM], [AX_USER_ID], [SQL_DURATION], [SQL_TEXT], [CALL_STACK], [TRACE_CATEGORY], [TRACE_EVENT_CODE], [TRACE_EVENT_DESC], [TRACE_EVENT_DETAILS], [CONNECTION_TYPE], [SQL_SESSION_ID], [AX_CONNECTION_ID], [IS_LOBS_INCLUDED], [IS_MORE_DATA_PENDING], [ROWS_AFFECTED], [ROW_SIZE], [ROWS_PER_FETCH], [IS_SELECTED_FOR_UPDATE], [IS_STARTED_WITHIN_TRANSACTION], [SQL_TYPE], [STATEMENT_ID], [STATEMENT_REUSE_COUNT], [DETAIL_TYPE], [STATS_TIME], [COMMENT]
FROM [AX_SQLTRACE]
ORDER BY [CREATED_DATETIME] DESC
-- HIDDEN_SCANS_QUERIES
-- Find Dynamics AX queries that only seek on DataAreaId
-- NOT USEFUL for other products
SELECT TOP 100 *
FROM HIDDEN_SCANS_CURR_VW
ORDER BY TOTAL_ELAPSED_TIME DESC
-- OPTION_FAST_QUERIES
-- Find queries option(fast) set that have sort operations
-- Dynamics AX only query
-- Either we don't have an index to match the order by clause
-- or the query is potentially to complex for SQL to pick that index
SELECT TOP 100 *
FROM QUERY_STATS_CURR_VW
WHERE SQL_TEXT LIKE '%OPTION(FAST%'
AND QUERY_PLAN_TEXT LIKE '%PhysicalOp="Sort"%'
-- USER_SCANS_QUERY
-- Find Dynamics queries that are scanning
SELECT TOP 100 *
FROM USER_SCANS_CURR_VW
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
Microsoft Dynamics CRM Team Blog: Update Rollup 3 for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 3 03.08.2011 09:11
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
Часовой пояс GMT +3, время: 19:48.
