Старый 01.10.2014, 02:11   #1
emeadaxsupport: Setting a limit for MS Dynamics AX 2012 RAM consumption?
Источник: http://blogs.msdn.com/b/axsupport/ar...nsumption.aspx
Have you come across this question already:
Is there an AOS server configuration setting available that might limit the AOS memory consumption?
Here comes the answer for you:
Yes, there is an AOS server setting called “MaxMemLoad” (http://technet.microsoft.com/en-us/l.../aa569637.aspx ) where you can limit as a percentage value.
Example: If you set this value = 80 and you have 10 GB of available RAM from hardware perspective then AOS server would not consume more than 8 GB.
emeadaxsupport: New and updated content is available for cumulative update 6 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 27.06.2013 19:11
dynamics-community.at: Dynamics AX 2012 Trainings Blog bot DAX auf Deutsch 0 19.06.2012 18:11
emeadaxsupport: In Microsoft Dynamics AX 2012, compiler output setting of Message Window may cause errors when generating (incremental) CIL Blog bot DAX Blogs 0 16.03.2012 23:12
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
Часовой пояс GMT +3, время: 13:27.
