Старый 01.11.2012, 17:11   #1
sashanazarov: Exporting to Excel with Microsoft.Dynamics.AX.Fim.Spreadsheets.* classes
Источник: http://sashanazarov.blogspot.com/201...xcel-with.html
While looking for a way to export to Excel in batch, I investigated what they do in financial statements (LedgerBalanceSheetDimPrintExcelEngine class).
Pros:
  • It is possible to use these .NET components in batch on the server side
  • Execution is way faster than that of the SysExcel* classes
Cons:
  • It looks like it is not possible to create more columns than there are letters in the English alphabet
  • Less flexible comparing to standard SysExcel classes, so manual formatting will likely be needed in the end.
static void AnotherWayToExportToExcel(Args _args)
#define.ReadWritePermission('RW')
#define.FileName('c:\myFile.xlsx')
#define.ExcelColumnWidth(15)
#define.ExcelCellFontSize("Microsoft.Dynamics.AX.Fim.Spreadsheets.CellFontSize")
#define.Size9("Size9")
CustTable custTable;
Microsoft.Dynamics.AX.Fim.Spreadsheets.Spreadsheet spreadsheet;
Microsoft.Dynamics.AX.Fim.Spreadsheets.CellProperties cellProperties;
Microsoft.Dynamics.AX.Fim.Spreadsheets.ColumnProperties columnProperties;
void addColumn(str _name)
columnProperties = new Microsoft.Dynamics.AX.Fim.Spreadsheets.ColumnProperties();
columnProperties.set_Width(#ExcelColumnWidth);
spreadSheet.InstantiateColumn(columnProperties);
cellProperties = new Microsoft.Dynamics.AX.Fim.Spreadsheets.CellProperties();
cellProperties.set_FontSize(CLRInterop::parseClrEnum(#ExcelCellFontSize, #Size9));
cellProperties.set_Bold(true);
spreadSheet.AddStringCellToWorkbook(_name, cellProperties);
new FileIOPermission(#FileName, #ReadWritePermission).assert();
spreadSheet = new Microsoft.Dynamics.AX.Fim.Spreadsheets.Spreadsheet();
if (!spreadSheet.CreateSpreadsheet(#FileName))
throw error(strFmt("@SYS72245", #FileName));
addColumn("Customer name");
addColumn("Balance");
while select custTable
spreadSheet.MoveToNextRowInWorkbook();
spreadSheet.AddStringCellToWorkbook(custTable.name(), cellProperties);
spreadSheet.AddNumberCellToWorkbook(real2double(custTable.openBalanceCur()), cellProperties);
spreadSheet.WriteFile();
spreadSheet.Dispose();
CodeAccessPermission::revertAssert();
Output:
Старый 05.01.2015, 17:22   #2
b_nosoff is offline
b_nosoff
Читатель
Аватар для b_nosoff
197 / 143 (5) +++++
Записей в блоге: 13
Angry Excellent design
It's worth mentioning that only up to 26 columns are allowed. Through A to Z. No more.
Axapta non erubescit
Старый 05.01.2015, 18:03   #3
Stitch_MS is offline
Stitch_MS
Аватар для Stitch_MS
397 / 483 (17) +++++++
Сообщение от b_nosoff Посмотреть сообщение
Yes
Cons:
За это сообщение автора поблагодарили: b_nosoff (1).
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 11 Blog bot Dynamics CRM: Blogs 0 06.10.2012 05:27
Microsoft Dynamics CRM Team Blog: Fast, Efficient Growth for Project Management Solution - Case Studies Blog bot Dynamics CRM: Blogs 0 01.02.2012 03:18
DynamicsAxSCM: Operational Sites in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.05.2011 19:11
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
dynamics-ax: Official Details about Dynamics AX '6' released, including comments from Microsofts Kees Hertogh Blog bot DAX Blogs 0 11.01.2011 05:22
Часовой пояс GMT +3, время: 05:24.
