Старый 16.02.2015, 08:11   #1
Malaysia: AX SSRS - copy report design from one VS to another VS
Источник: http://axmas.blogspot.com/2015/02/ax...om-one-vs.html
Purpose of such action
Scenario:
SSRS Report has alot of report design. If export/import via XPO, may cause AOT to hang, or load too long while importing. This works for situation where you only want to update one report design. Only works where you have access rights to develop in Visual Studio. Steps:
  1. Open visual studio, browse through the Application Explorer and locate the SSRS > Report, and open the report you required.
  2. Open only the desired report design, nothing else.
  3. Select any object, right click and open its properties (textbox properties). Copy the textbox name (for example, textbox123).
  4. In the report designer, find or click Ctrl + f, find any object in the report design, in this case, find "textbox123". It will open the XML code of the report.
  5. Copy the XML code, do the same at the destination Visual Studio, and paste the code there.
copy object name
find object name to open the XML codes
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
Malaysia: How to save the SSRS report to PDF/HTML through code in dynamics ax 2012. Blog bot DAX Blogs 0 24.01.2014 01:15
kamalblogs: SSRS Tip: Prevent report execution through controller – Dynamics Ax 2012 Blog bot DAX Blogs 0 25.09.2013 14:11
bojensen: Dynamics AX 2012 error when running SSRS-reports just after deleting a table field from report’s temporary table – Addicted2AX / Addicted2SQL Blog bot DAX Blogs 0 09.01.2013 17:11
Часовой пояс GMT +3, время: 22:05.
