Старый 28.02.2015, 14:12   #1
DeniZone: 2 examples of importing multiple files
Источник: http://denizone.blogspot.com/2015/02...ple-files.html
In AX, the typical way to import files via the UI is to do it one file at the time. If you have multiple files to import there are several options on how to do this via the AIF.
Every once in a while, it could be useful for the end-user to have the option of importing several files through the UI.
I have found two similar examples on how to achieve this:
Example 1)
static void MultiFileSelectDlgTest_1(Args _args)
System.Windows.Forms.OpenFileDialog ofd;
System.String[] s2;
int counters;
str imageValaue;
int i;
ofd = new System.Windows.Forms.OpenFileDialog();
ofd.set_Title("Select files");
ofd.set_Multiselect(true);
if (ofd.ShowDialog() == System.Windows.Forms.DialogResult::OK)
s2 = ofd.get_FileNames();
counters=System.Convert::ToInt32( s2.get_Length());
for(i = 0 ; i
DeniZone: Importing an Excel spread sheet with multiple columns Blog bot DAX Blogs 0 21.02.2015 17:12
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
Gareth Tucker: Scribe Insight and Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 06.05.2012 02:18
emeadaxsupport: Multiple database data files, table partitioning using multiple file groups… and Microsoft Dynamics AX 2009 Blog bot DAX Blogs 3 04.10.2011 16:30
Microsoft Dynamics CRM Team Blog: Importing Multiple Files using ZIP Import Blog bot Dynamics CRM: Blogs 0 16.03.2010 00:05
Часовой пояс GMT +3, время: 07:50.
