Старый 23.08.2015, 02:46   #1
Prabhats: DAX 2009: SoapServerException when installing Role Center & Enterprise Portal in Dynamics AX 2009
Источник: http://ferventcoder.com/Prabhats/arc...se-portal.aspx
Originally posted on: http://ferventcoder.com/Prabhats/arc...se-portal.aspx
Entering function CurrentUserAlias
    Leaving function CurrentUserAlias
    Creating new Enterprise Portal Site with following the parameters:\n URL: http://Portal/sites/EP\n Title: EP Site\n LCID: 1033\n OwnerLogin: WE\AxAdmin
    Administration Web Service URL: http://machine:90/_layouts/ep/WSSAdmin.asmx
    Information: Debugging mode is off.
    An error occured while Setup was creating a new site.
    Exception of type 'Microsoft.SharePoint.SoapServer.SoapServerException' was thrown.
    The Web site http://portal/sites/CEC was not created correctly.  An error has occurred on the server.
System.Web.Services.Protocols.SoapException
   at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
       at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
       at Microsoft.Dynamics.Framework.Deployment.Portal.WSSAdmin.CreateSite(String Url, String Title, String Description, Int32 Lcid, String WebTemplate, String OwnerLogin, String OwnerName, String OwnerEmail, String PortalUrl, String PortalName)
       at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.CreateDefaultEPSite(String virtualServerUrl)
RESOLUTION:
1. Make sure the Sharepoint Folder - Program Files/ Common Files/Microsoft Shared/Web Server Extensions/12 has required permissions and is not read-only/compressed
2. Make sure the host header for the sharepoint web application into which EP site will be deployed is configured (do not use the host header while installing Role Center/EP - for some reason the installer has conflicts when dealing with host header)
Prabhats: DAX 2009 Enterprise Portal Development : Using the Ax Session Blog bot DAX Blogs 0 12.07.2015 16:17
emeadaxsupport: Sample steps on installing and configuring SharePoint 2010 and deploying AX 2009 Role Centers and Enterprise Portal Blog bot DAX Blogs 0 14.02.2011 21:11
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
gatesasbait: Installing Reporting Services, Analysis Services and Enterprise Portal for AX 2009 Blog bot DAX Blogs 0 03.07.2008 02:05
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Часовой пояс GMT +3, время: 21:54.
