Старый 28.08.2015, 11:33   #1
rkorchagin is offline
rkorchagin
Cool Запаковка в ZIP архив
Было задание запаковать файл прямо в аксапте. На основе интернета написал такую функцию. Может кому пригодится.
boolean zip(str sSourceFile, str sTargetZIPFile)
    str fzip;
    FileName tmpFileName;
    FileName tmpZipFileName;
    boolean retVal;
    AsciiIO file;
    int ret;
    if (!(sSourceFile && sTargetZIPFile))
        return retVal;
    //Windows vbScript
    fzip += '\n'+'Dim oShellApp, oFSO, sSourceFile, sTargetZIPFile, oZipFile, objFolder';
    fzip += '\n'+'Set oShellApp = CreateObject(\"Shell.Application\")';
    fzip += '\n'+'Set oFSO = CreateObject(\"Scripting.FileSystemObject\")';
    fzip += '\n'+'sSourceFile = Wscript.Arguments.Item(0)';
    fzip += '\n'+'sTargetZIPFile = Wscript.Arguments.Item(1)';
    fzip += '\n'+'\'Write the fileheader for a blank zipfile.';
    fzip += '\n'+'Set oZipFile = oFSO.OpenTextFile(sTargetZIPFile, 2, True)';
    fzip += '\n'+'oZipFile.Write \"PK\" & Chr(5) & Chr(6) & String(18, Chr(0))';
    fzip += '\n'+'oZipFile.Close';
    fzip += '\n'+'\'Start copying file into the zip from the source folder.';
    fzip += '\n'+'Set objFolder = oShellApp.NameSpace(sTargetZIPFile)';
    fzip += '\n'+'if not objFolder is nothing then ';
    fzip += '\n'+'    objFolder.CopyHere sSourceFile';
    fzip += '\n'+'    \'Because the copying occurs in a separate process, the script will just continue.  Run a DO...LOOP to prevent the function';
    fzip += '\n'+'    \'from exiting until the file is finished zipping.';
    fzip += '\n'+'     Do';
    fzip += '\n'+'        WScript.Sleep 1000';
    fzip += '\n'+'     Loop While objFolder.Items.Count < 1';
    fzip += '\n'+'End If';
    tmpFileName = Winapi::getTempFilename(WinApi::getTempPath(),'_zip');
    tmpFileName = strreplace(tmpFileName,'.tmp','.vbs');
    tmpZipFileName = Winapi::getTempFilename(WinApi::getTempPath(),'_tz');
    tmpZipFileName = strreplace(tmpZipFileName,'.tmp','.zip');
//    info(strfmt('temp script file: %1',tmpFileName));
//    info(strfmt('temp zip file: %1',tmpZipFileName));
    if (WinApi::fileExists(tmpFileName))
        WinApi::deleteFile(tmpFileName);
    if (WinApi::fileExists(tmpZipFileName))
        WinApi::deleteFile(tmpZipFileName);
    //BP Deviation documented
    file = new AsciiIO(tmpFileName,'w');
    file.outRecordDelimiter('\n');
    if (file)
        file.write(fzip);
        file = null;
        ret = Winapi::shellExecute('wscript.exe',strfmt('\"%1\" \"%2\" \"%3\"',tmpFileName,
                        sSourceFile,
                        tmpZipFileName),'','',0,true);
        //Sleep(1000);
        if (ret && Winapi::fileExists(tmpZipFileName))
            if (WinApi::fileExists(sTargetZIPFile))
                WinApi::deleteFile(sTargetZIPFile);
            ret = WinApi::moveFile(tmpZipFileName,sTargetZIPFile);
            if (!ret)
                retVal = true;
    return retVal;
За это сообщение автора поблагодарили: macklakov (5), Ace of Database (3),  (1).
shellexecute, vbs, zip, архив, запаковка, паковать
Разархивирование zip архива встроенным в windows архиватором vad21 DAX: Программирование 17 08.04.2016 08:59
palleagermark: How to make a ZIP file from AX 2012 R2 CU7 Blog bot DAX Blogs 0 07.04.2014 11:11
Zip-архивирование средствами Windows 2008 Damn DAX: Программирование 16 26.11.2013 19:58
palleagermark: Create ZIP files from AX Blog bot DAX Blogs 0 28.11.2011 17:11
Как разархивировать zip архив? slava09 DAX: База знаний и проекты 33 25.02.2011 14:48
Часовой пояс GMT +3, время: 11:43.
