Старый 16.10.2015, 01:14   #1
emeadaxsupport: Troubleshooting Inplace Upgrade Script updateDirDartyRelationshipXDSLegalEntity()
Источник: http://blogs.msdn.com/b/axsupport/ar...galentity.aspx
You might recieve the following message when  running the upgrade script Classes\ReleaseUpdateDB62_GABMinor\updateDirDartyRelationshipXDSLegalEntity() during  an inplace upgrade from MS Dynamics AX 2012 R2 to R3:
“Cannot create a record in Party relationships (DirPartyRelationship). Invalid value specified for 'Expiration:'. It cannot be greater than or equal to the 'Expiration:' of the first record.”
One possible background could be unsufficient customer data quality in terms of partly missing data in the field “PartyID”
The following script is a slightly modified version of the standard script updateDirDartyRelationshipXDSLegalEntity(). It loops through the records sequentially instead of block wise and will list records where a PartyID might be missing:
“Microsoft provides programming examples for illustration only, without warranty either expressed or implied, including, but not limited to, the implied warranties of merchantability or fitness for a particular purpose. This blog post  assumes that you are familiar with the X++ programming language that is being demonstrated . Always test the script in test environments first in detail! ”
emeadaxsupport: Documentation collection: Inplace upgrade MS Dynamcis AX 2012 RTM --> AX 2012 R2 CU7 Blog bot DAX Blogs 0 22.06.2014 01:19
emeadaxsupport: Troubleshooting Upgrade and CU Batch jobs stuck in a waiting status in Dynamics AX 2012 Blog bot DAX Blogs 0 07.09.2013 05:53
emeadaxsupport: Invitation: Microsoft Dynamics AX 2012 R2 In-Place Upgrade – Overview, Troubleshooting and Tips (EMEA) - July 25th Blog bot DAX Blogs 0 02.07.2013 19:11
emeadaxsupport: Writing Data Upgrade Scripts Part 1: Understanding the components of the process Blog bot DAX Blogs 0 10.02.2012 05:16
Часовой пояс GMT +3, время: 15:04.
