Старый 27.04.2016, 10:11   #1
organicax: Item Vendor statistics report
Источник: https://organicax.com/2016/04/27/ite...istics-report/
If you are looking to negotiate a better price for an item that you might purchase from multiple suppliers then you can run the Item/Vendor statistics report which will show you the quantity of the items that you have purchased from different suppliers. You can specify different dates to filter on. If it’s an important raw material for example this might allow you to go to one supplier and work out a better deal or work out a more constant source of supply.
Here is a quick overview.
AX2012 R3 CU9
If you are looking at what you purchased from a specific supplier then the Vendor/Item statistics report might work better for you.
Cheers
Lachlan
Filed under: Procurement and sourcing
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
You experience issues when you run the "Physical inventory by inventory dimension" report and the "Physical inventory by item group" report in Microsoft Dynamics AX 2009 Vadik DAX: База знаний и проекты 0 27.08.2010 23:00
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 15:19.
