#1 |
In some companies it’s almost impossible to make a full index rebuild, because they have only a few hours of maintenance windows
You can adapt this script to rebuild a specific number of indexes during each day, during a specific hours. If you have several companies in a database you can even adapt it to rebuild each company at a specific hour of day. This scripts only runs in SQL Server 2005. This script isn’t complete you have to adapt it to your current company and define fragmentation values. Create a table to store indexes and values. -- TABLE OF INDEXES CREATETABLE IndexFragList ( DatabaseId INT, IndexId INT, ObjectID INT, IndexName CHAR(255), AvgFrag DECIMAL, TableName VARCHAR(255) ) -- ############ SCRIPT ############################# DECLARE @Maxfrag DECIMAL DECLARE @Minfrag DECIMAL DECLARE @DatabaseID INT DECLARE @IndexId INT DECLARE @IndexName VARCHAR(255) DECLARE @AvgFrag DECIMAL DECLARE @ObjectID INT DECLARE @TableName VARCHAR(6000) DECLARE @Command VARCHAR(255) DECLARE @Count INT -- Decide on the maximum fragmentation to allow SELECT @Maxfrag = 30.0 SELECT @Minfrag = 0.05 SET @COUNT =(SELECTCOUNT(*)FROM IndexFragList) PRINT'COUNT.....'+CONVERT(VARCHAR(10), @COUNT) IF @COUNT = 0 BEGIN -- FILL INDEXES INSERTINTO IndexFragList(DatabaseId, IndexId, ObjectID, IndexName, AvgFrag, TableName) SELECT a.database_id, a.index_id, a.object_id, b.name, avg_fragmentation_in_percent avg_frag, t.name FROM sys.dm_db_index_physical_stats (DB_ID(),OBJECT_ID(N'Production.Product'),NULL,NULL,NULL)AS a JOINsys.indexesAS b ON a.object_id= b.object_idAND a.index_id = b.index_id JOINsys.tablesas t ON a.object_id= t.object_id AND avg_fragmentation_in_percent > @Minfrag END -- CUSTOMIZE THIS -- IF CAN FILTER BY COMPANY, ETC DECLARE indexes CURSORFOR SELECT DatabaseID, IndexId, ObjectID, IndexName, IndexId, AvgFrag, TableName FROM IndexFragList ORDER BY AvgFrag DESC OPEN indexes FETCHNEXTFROM indexes INTO @DatabaseID, @IndexId, @ObjectID, @IndexName, @IndexId, @AvgFrag, @TableName WHILE@@FETCH_STATUS= 0 BEGIN SET @Command='ALTER index ['+RTRIM(@IndexName)+'] ON ['+ @TableName +'] ' -- REBUILD INDEX IF @AvgFrag > @Maxfrag BEGIN SET @Command=@Command +' REBUILD' EXEC(@Command) END -- REORGANIZE INDEX ELSEIF(@AvgFrag > @Minfrag)AND(@AvgFrag > @Maxfrag)BEGIN SET @Command=@Command +' REORGANIZE' EXEC(@Command) END DELETEFROM IndexFragList WHERECURRENTOF indexes -- CUSTOMIZE THIS -- YOU CAN BREAK BY HOURS, NUMBER OF INDEXES, ETC BREAK; FETCHNEXTFROM indexes INTO @DatabaseID, @IndexId, @ObjectID, @IndexName, @IndexId, @AvgFrag, @TableName END CLOSE indexes DEALLOCATE indexes Подробнее... http://dynamicsuser.net/blogs/nunomaia/arc...ql-indexes.aspx
