Старый 05.12.2009, 00:56   #1
In this post from April, I explained how to make dynamic references to page based Web Services, but the post really left the developer with a lot of manual work to do using reflection.
So – I thought – why not create a couple of helper classes which makes it easier.
Basically I have created a generic NAVPageServiceHelper class, which encapsulates all the heavy lifting of reflection and leaves the developer with a set of higher level classes he can use.
The service helper will have a collection of classes explaining various information about the fields and has methods for getting or setting the value (and setting the corresponding _Specified automatically as well).
The primary reason for making this is of course to make Edit In Excel bind to any page without changing anything, but the method can be used in a lot of other scenarios.
2 projects: NAVPageFieldInfo and NAVPageDynamicWebReference
I split the PageServiceHelper and the PageFieldInfo into two seperate projects. NAVPageFieldInfo just contains the FieldInfo classes for all the supported field types and a collection class.
NAVPageFieldInfo is the abstract base class
BooleanFieldInfo is the field info class for a boolean field
OptionFieldInfo is the field info class for an option field
IntFieldInfo is the field info for…
You get it – all in all, the following types are supported:
String, Decimal, DateTime, Int, Option, Boolean
Furthermore, there is a class called NAVFields, which derives from List<NAVFieldInfo>, for keeping a collection of the fields.
NAVFields has a method called PopulateFieldsCollection, which takes an object type and a fields enum type and based on this, instantiates all the NAVFieldInfo classes – let’s look at the code.
/// <summary>
/// Populate Fields Collection with NAVPageFieldInfo for all properties in the record
/// Should works with any NAV 2009 Page exposed as WebService
/// </summary>
/// <param name="objType">Type of Object (typeof(Customer), typeof(Vendor), ...)</param>
/// <param name="fieldsType">Type of the Enum holding the property names</param>
private void PopulateFieldsCollection(Type objType, Type fieldsType)
    // Key property is not part of the Enum
    // Add it manually as the first field
    AddField("Key", objType);
    // Run through the enum and add all fields
    foreach (string field in Enum.GetNames(fieldsType))
        AddField(field, objType);
/// <summary>
/// Add a NAVPageFieldInfo for a field to the fields collection
/// </summary>
/// <param name="field">Field name</param>
/// <param name="objType">Type of Object in which the field is (typeof(Customer), typeof(Vendor), ...)</param>
private void AddField(string field, Type objType)
    field = VSName(field);
    PropertyInfo pi = objType.GetProperty(field, System.Reflection.BindingFlags.Public | System.Reflection.BindingFlags.Instance);
    if (pi != null)
        NAVPageFieldInfo nfi = NAVPageFieldInfo.CreateNAVFieldInfo(objType, field, pi, objType.Namespace);
        if (nfi != null)
            // If we encounter unknown Field Types, they are just ignored
            this.Add(nfi);
As you can see, the AddField method calls a static method on NAVPageFieldInfo to get a FieldInfo class of the right type created. That method looks like:
/// <summary>
/// Create a NAVPageFieldInfo object for a specific field
/// </summary>
/// <param name="field">Name of the property</param>
/// <param name="pi">PropertyInfo for the property on the record object</param>
/// <param name="ns">Namespace for the record object (namespace for the added WebServices proxy class)</param>
/// <returns>NAVPageFieldInfo or null if the type isn't supported</returns>
public static NAVPageFieldInfo CreateNAVFieldInfo(Type objType, string field, System.Reflection.PropertyInfo pi, string ns)
    if (pi.PropertyType == typeof(string))
        // String Property - is it the KeyField
        if (field == "Key")
            return new KeyFieldInfo(field, pi, null);
        else
            return new StringFieldInfo(field, pi, null);
    PropertyInfo piSpecified = objType.GetProperty(field + "Specified", System.Reflection.BindingFlags.Public | System.Reflection.BindingFlags.Instance);
    if (pi.PropertyType == typeof(decimal))
        // Decimal Property
        return new DecimalFieldInfo(field, pi, piSpecified);
    if (pi.PropertyType == typeof(int))
        // Integer Property
        return new IntFieldInfo(field, pi, piSpecified);
    if (pi.PropertyType == typeof(bool))
        // Boolean Property
        return new BooleanFieldInfo(field, pi, piSpecified);
    if (pi.PropertyType == typeof(DateTime))
        // DateTime Property
        return new DateTimeFieldInfo(field, pi, piSpecified);
    if (pi.PropertyType.Namespace == ns)
        // Other Property Types, in the same namespace as the object
        // These are enum's - set up restrictions on OptionFields
        return new OptionFieldInfo(field, pi, piSpecified, Enum.GetNames(pi.PropertyType));
    return null;
No more magic!
And actually the constructor for NAVFields – takes the object type and the field type as parameters for the constructor:
public NAVFields(Type objType, Type fieldsType)
    : base()
    this.PopulateFieldsCollection(objType, fieldsType);
Meaning that all it takes to utilize the NAVFieldInfo subsystem is instantiating the NAVFields class, which doesn’t necessarily need a dynamic web reference helper, but could also be instantiated through:
NAVFields fields = new NAVFields(typeof(Customer), typeof(Customer_Fields));
If you have some code, which needs to access data loosely coupled, NAVFields is a great way to get going.
The other project is the NAVDynamicPageWebReference – which really is a combination of the Dynamic Web References post from April and a Page Service Helper class.
The way you get a reference to the Dynamic Web Reference is much like in the post from April:
Assembly customerPageRef = NAVPageDynamicWebReference.BuildAssemblyFromWSDL(
  new Uri("
Часовой пояс GMT +3, время: 19:53.
